Zeitronix zt-2 wideband install questions....?
MarkyGsX
80
Aug 27, 2004
Carson, California
I just bought a zeitronix zt-2 wideband to tune my maft and 550's....my question is regarding the wiring....is there an aftermarket map sensor harness that i have to purchase to wire the boost sensor wires to on the wideband or can i wire them to my stock map sensor some how...? anyone with experience installing this wideband....any tips or advice...?
You need a 3.5bar MAP sensor to wire into the zt-2. You will have to tap your IC pipe somewhere to install it.
Zeitronix is selling their MAP sensor for $109 right now, which is a pretty good deal.
http://www.zeitronix.com/order/order.htm
Chris
what map sensor are you refuring to?
if you bought the ZT-2 boost selinoid then there should be a harness from zietronix, otherwise you should just make one.
if your using a map sensor, it might not work you will have to check with zietronix.
your dsm doesn;t have a map sensor, but a maf sensor, and it willnot log boost, just show air consumption value. if you want a boost level, just have someone watch your boost gauge when you log. ;)
The zeitronix doen't read off your MAF. It reads off of a 3.5bar MAP sensor, which you have to buy and install somewhere in your IC piping. With the sensor installed, you can indeed log boost, along with RPM's, TPS, AFR, and EGT's (if you buy the probe).
Chris
I figured I would post a equal part that was cheaper. you can buy the GM 3 bar map sensor for most parts stores for half the price if you count shipping. The GM PART # 12223861(new) and 16040749(old). The summitracing part # is MSD-2313 for $53 and free shipping. :D
