S-AFC wiring install?
jimmyjfnf
Nov 5, 2002
Ashland, Ohio
I'm trying to install an apexi s-afc into my 97 eclipse GST. Different sites are telling me different wires to connect to the MAP sensor wire. Is it the yellow/white wires or the pink/orange wires? If someone can direct me to the correct site or just tell me which ones that would help. I've checked RRE, here, Apexi-usa.
Thanks,
Dave J
I bought it from JDM. No instructions came with it. It just said to download them.
Thanks
Dave J
I got mine from Japan. JDM. And it didn't have instructions with it. I downloaded them from different sites and that's where I got all mixed up. They all had different installation instructions. I have to hooked up and ready to go now.
Thanks,
Dave J
What about this:
I originally ran a VPC, and then added the S-AFC (new-style) to the mix, and it was set up to get it's MAF signal from the VPC output, as you might guess.
Well ovet the past couple years, they;ve been talking about this MAP-controlled AFC setup. I've seen instructions and whatnot but those are all on MAF-based DSMs. How does a VPC-equipped DSM work with this? I yanked the VPC and AFC from the old car and plan to install it on the virgin wiring of the GSX.
On a side note, I also plan to make the AFC-portion of the harness "quick-removable", using a generic multi-wire electrical connector, and a bridge plug for the MAF signal. Just thought it would be nice to do in the first place...
