Fuel pressure
Jetblack
149
Apr 5, 2003
Baton Rouge, Louisiana
I need to know what fuel pressure I need to be at on a 6-bolt block with a 2g head, do I use 1g fp or 2g fp?
You use 2G FPR. Remember that you're still using 2G ECU and all maps to control fuel, and it's all made to work with stock 2G fuel pressure setting.
10-4, I couldn't think what the pressure was dependent on, thanks.
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
