Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 11-06-2002, 09:40 AM   #1 (permalink)
Proven Member
Region: Gulf Coast
Classifieds Rating: (1)
Reputation: AlmostStock TSi is an unknown
need help quick . . . ecu question
i have a simple question that i have never heard asked or answered before.if putting a 2g mas on a 1g manual it evens out(almost) with 550's, my question is, will putting a 2g mas on a 1g auto and 450's even out since stock injectors on autos are like 390's or so. need to know for a friend. thanks in advance.
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 11-06-2002, 10:23 AM   #2 (permalink)
DSM Wiseman
Classifieds Rating: (2)
It will never even out unless you get an afc. It will run ok, as stated inthe earlier posts, but trust me on this.... your car will not run good with larger than stock injectors unless you have an afc. Accept in the case of your auto, 450's are fine for that, but if you go with a 2g maf you will be on the lean side
____________________________
Austin
Offline
Old 11-06-2002, 10:27 AM   #3 (permalink)
Proven Member
Region: Gulf Coast
i know it will never even out w/o a fuel controller, i also know that with a 2g mas on a 1g manual w/ 550's that you do not NEED an afc to use them as they will run just fine(a little on the rich side). and with 510's its even closer to even, i have run similiar set ups on my car(s). my question was that a friend of mine has a 1g auto and i have a 2g mas and some 450's and was wondering if it would be as close as a 1g manual w/ 2g mas and 550's
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.12212491 seconds (57.25% PHP - 42.75% MySQL) with 9 queries
