2G safc sensor chk
ILOSE
206
Jun 6, 2002
Could someone with a 2G check their SAFC and go to etc, then sensor check, There is IN:1, IN:2 and THR%.
And see what the IN:2 voltage shows with the key in the start position not running and then also with the car running.
I am trying to diagnose a no-start and this is something that maybe related.
#2 reading is the O2 reading if you hook up the blue wire on the AFC. It is not related to what you are trying to diagnose.
