AFR on racegas... PLEASE HELP!!!!!!!!
squeak10686
360
Jul 18, 2004
omaha, Nebraska
Alright guys here is the question... I should be running 105 octane gas at the track and would really like to know how many pounds i should be able to push out of the car... AND ALSO what my air fuel ratio should be out of my LM1.... here is the list of my mods
3 inch exhaust
Dejon tool intake/ filter
550cc Injectors
Safc
Mitsu head gasket
Arp headstuds
Innovate motorsports LM1
small 16g turbo...
Act 2600
Supra sidemount...
Just give me an amount of boost that I could push out of it, and also on race gas what my Air fuel should be...
I also might run a 55 shot to it and would like to know how much boost i could run with that... just a few questions thanks for the help
Happy tuning - Andrew-
On that turbo I would shoot for around 22-23lbs of boost and on race gas shoot for 11.8-12.0 A/F ratio
Now with nitrous, start out at a low boost and work your way up, monitoring knock and A/F, keep the A/F conseritive, say like 11.2-11.4 A/F.
I have learned that anything leaner then 12.0 I have not made any more power, so why go leaner? makes sense to keep it alittle on the rich side to save the motor.
On my 11.1 @130mph pass I was running 10.6 A/F ratio!!! OMG pig ass rich I know, and that was on c16 race gas.
good luck man.
-Jake
is that the safepoint on that turbo... like 22 pounds??? i hsould probably get some arp head studs...
andrew, get your ARPs and HG first....
after that, on the 16g, 20psi is a nice number for it....if your of nitrous, then like they said, start low boost and work your way up tuning conservatively.....i remember running 24 psi on my old 16g and as strong as it felt, i dont think that would be in a 16g's efficiency range
is 105 the highest you can get? If so then run that. But if you can get 110 or 114 get that.
On 110 leaded my afr was 12.5:1 at 26psi dropping really fast (look at graphs), and made 338awhp. You have to multiply by 1.17 to get what a dynojet would read. But anyway, on pump gas i am around 11.5:1
Also the 16g the higher boost you run will make more torque but not more power, 24psi is about the limit on making more power but i kept making more torque as the boost went up. But it dropped off so fast, this is why i turned it up so boost would stay above 20psi longer. Anyway with 110 id shoot for 24psi and around 12.3:1 afr as long as timing is still good. But dont lissen to us, go run the car and see how it reacts to each psi, thats what i did. Here are my dyno charts for race gas, this was a 110/93 mix
Torque and HP
Boost and AFR
sorry they are a little blury but you get the idea, and get a fmic.
i believe that i am going to be getting a supra sidemount... now secondly... do you think it would alright for me to get a pocketlogger instead of the wideband... or should i just save up the extra money and buy myself a wideband...
Id get a logger, and tune for best timing. Wideband is good but both are better.
  • For sale 2g 2g auto shift inhibitor with plug
    2g auto shift inhibitor with weather pack plug. Price is shipped USPS. Message 702-741-6987
    • 19Eclipse90
  • For sale '90 Laser turbo
    • GregPLT
    • pottersgst
  • For sale JFH REAR
    JFH Auto LSD REAR
    • pottersgst
