PSI NRG
- 328
- 5
- Nov 2, 2004
Solon,
Ohio
My buddy's car is acting kinda funny.... with in the last 5 months he installed a gt28 turbo, bigger injectors, fuel pump and an EGT gauge. His EGT Reads really close to 1600 when hes boosting towards the higher rpms but his A/F gauge is reading all the way rich so its not leaning out does that make any sence? What would cause it to be running so hot? the EGT probe is on the manifold runner on the far right about 4- 5 inches away from the block which i think is where its susposed to be correct? I'm not sure if this would make any difference but he had to move his cooling fan from the right side to the left side to make room for the exteral wastegate so its not even cooling the turbo... other than that we cant think of a reason that would cause such high temps any one have any ideas?
