Big Woo
DSM Wiseman
- 458
- 22
- Sep 9, 2002
Grand Rapids,
Michigan
I have several DSM's, but I am wondering if I could run 550cc injectors with the stock (modified) MAS sensor without an AFC or AFR? If so are there other ways to lean out the system eniugh? Any help here would be great I can run the stock 450's, but was wondering. I am just trying to use my old stuff, for a winter car with a couple of more berries. Also any way to eliminate fuel cut, or trick the ECU so that it will not happen until 7000 or 7500 rpm? Please keep in mind that I do not mind spending money on my cars, but this project is all about making the most out of what I already have. thanks for the help.
The car is a 1990 GS-T that I picked up dirt cheep, and I have an asortment of left over go fast goodies from previous upgrades on other cars (90 talon awd, and a 93 GSX) that I have marked for the GST like a ported ex man, 16g, O2 housing, 2.5" turbo back exhaust, turbonetics detlagate, HKs superpower flow & a K&N, UIC pipe, Ported head, and intake, Denzo fuel pump, and the 550's.
Big WOO
Big WOO
You should have just realised you made a mistake and appologised, however....
... you don't know me so don't assume anything. I can help you a great deal since I have 550s, an AFC and am one of the best DSM resources for hacking the 1G MAF up. But instead of just taking the right path you decided to flame back. So I decided to use you as an example. The older DSM crowd is getting more and more sick of people who want to be spoon fed. The end result is that we are leaving the boards... who loses out... you because we take our experience with us. If you want us to reply the least you can do is a little searching yourself first. Effort in = effort out.
. Consider this your initiation.
