Actually your AFC setting should be around the ballpark of -37.5% on pump gas. On race gas, you may have a problem not able to lean it out enough.
Like you said, I wont go with 720cc injectors with a 14B.
Quote:
Originally posted by NOSLO2PT0
Good luck with that. 720's are 62.5% larger than 450's. AFC only allows you to take out 50% fuel. Get a 2G MAS and it COULD be done. Still won't make any power, as you won't be able to lean the car out enough on race gas. Just upgrade injectors when you upgrade a turbo. 450's have gone 12's easily.
Mike
