6 bolt 4g64 2.4 pistons
jazzyjay
216
Mar 27, 2003
I am trying to find pistons for the 6 bolt 4g64 2.4 short block all I can come up with is Wiseco. Not that they are bad piston but I like to have a choice. Put part number if you know of a piston I can use.
Email Mike @ SBR... he got me hooked up with some 8.5:1 CR "CP" custom pistons for my 6-bolt 4g64 build. I specifically requested them to have both compression ring grooves to be 1.5mm thick (something I really liked about the set of Arias that I had for my old 2.3L setup). Unlike the Wiesco stroker pistons that only offered 1.5mm top and 1.2mm ring grooves (At least for the 2.3L stroker configuration).
So far (~1k miles on the 4g64) they are holding up fine!
    • eclipsemf
