Smog Help!!
arodgst
409
85
Mar 31, 2008
Bakersfield, California
Hey guys I am going to need to pass smog again this year legit if i can...if anyone is deleting their emission lines and valves all to emission stuff please let me know if not I could use some "help" getting it smogged this year...thanks for a 98 if that helps any.
Its not that I need seafoam whcich I wish thats all I needed it is because I got my car without emission set up and been doing smogs with "help" but I wanna do it legit and put all emissions lines and solenoids on it like the way its supposed to be.
Its not just the emissions sensors/vacuum lines you should be worried about, from that list of mods there are a few things that will fail you. I copy/pasted your mods list and highlighted what bolt-on's will more than likely fail you...
Bolt-on Modifications:
Small16g // external dump with tial 38mm wastegate//fmic// 1g bov//autometer boost gauge//AEM eugo wideband//3in punishment racing dp cat deleted with 3" catback//FP exhaust manifold ////wally 190 fp, evo 560//evo3 intake manifold//egr delete//isc block off plate//hacked maf and snorkle tube//power steering and ac deleted//water turbo lines deleted//
Engine Management:
-evoscan -autometer boost gauge -aem wideband -safc II
Engine Internals:
-3mm revised lifters -bs eliminated -arp head stud -oem longblock rebuild
Drivetrain Modifications:
...clutch//ss clutch line master to slave//fidanza aluminum flywheel//galant es tranny with axles
Suspension Modifications:
Khumo ecstas all season//tokico hp shocks with tenzo lowering springs(gsx set up) front and rear strut bars//drilled slotted rotors ceramic brake pads
When I needed to pass emissions I went to the nearest junkyard and pulled it, that's going to be the easiest/cheapest way to get some emissions stuff unless a local is willing to give you theirs.
Good luck!
:dsm:
^^ thanks for the replies. I failed to mention that i have all other stock parts ready to go like yhe internal gated hotside, another stock maf...i basically have all other stock parts i took off originally except the lines and solenoids n' what not...thanks though.
If you can't pass legit, PM me and I have an "alternative"...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
