FAQ Article Requests - post them here
Ludachris
Founder & Zookeeper
8,878
4,725
Nov 12, 2001
Newcastle, California
If you have an article you'd like to see written up in our Tech Article section:
http://www.dsmtuners.com/tech.php
Please reply to this post and request it. Make sure you've already looked through the articles section thoroughly to make sure you're not requesting an article that is already posted. No discussions here please - just requests.
Was wondering how to DYNO tune a pocket logger and s-afc. I seen tech articles on how-to street tune the pocket logger but none on how to really DYNO tune the logger. I was planning on making a trip to the dyno soon and wanted to be prepared. I looked on V-FAQ but didn't really see anything on this topic. If I just over looked it a link would be much appreciated.
how about an idiot light tech article with pics of each and what they are?
I would like to see a "correct" boost controller instal. Even with a simple manual boost controller there still seems to be alot of mixup as in where and how it should go in and what vacum lines should be left where. Also what to do with the stock boost control selinoid
Ive tried finding info as to lay outs, designs and spec for the mitsu evo111 but I havent been able to find anything (my search engines suck).
Since it is a 4g63 maybe you guys could help me find that info thanks in advance.
Would like to see a very well written tech article about replacing the clutch master and slave cylinders on all applicable dsms. Included should be the need to replace both the leaking component as well as the other (any good DSMer who writes the article can explain why both need replacing) cylinder. Why you should not adjust the set screw prior to fully bleeding the system and verifying it is just that, and some of the common symptoms of one or the other going out. I have enough experience to do it myself but not enough to be able to swear by it and tell others how. Any help would be greatly appreciated.
Doug
I would love to see a way to get a manual steering rack into a 2gen. Like from a 1.8L or something. I would just take out my power stuff but im interested in autoX this year.
I'd like to see an article about installing an Underdrive pulley. i am getting one very soon and would like to see how to install it. if its not up by the time i get it, i will write one up on how to install it, but installing mine will be a crash course lesson. ill document how i did it when i do it right.
A tech article on how to feed your turbo from the oil filter housing instead of the ehad or how to feed it from the oil filter housing and the head together. :talon:
A Fuel pump (walbro255 install) The one from vfaq is terribly worded IMO and I want some more pics if possible before during after...
i would like to build a custom sub box in my 93 gsx and leave the spare tire in there along with the cargo cover. has anyone done it? if so please help
p.s. pictures would be nice:)
thanks
Originally posted by mitsfit
:dsm: like to see "how to install a boost controller in a 2g" thanks!!!!!!
Done.
Here you go:
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=105573
Is there any way to remove your AC system? Mine's out of freon or whatever they use, I don't think I want to spend money to recharge it (Isn't it expensive?). It would be nice to trim a few pounds off.
this feat has only been accomplished by a few great 2gnt's but seems to have quite a bit of potential. with the recent addition of the srt4, this swap could be the next jump to keep us in the runnings. i'd like to see detailed instructions for correcting the crank timing, injector re-wiring, oil pan clearance, and maybe some design suggestions for the passenger engine mount. i know there is a core of people attempting this swap this year and hopefully we can promote some interest with a well written tech article...trust
