Banjo bolt size, fuel filter
92TALONAWD
43
Sep 5, 2002
Catonsville, Maryland
Hello, I wanted to know what size and thread pitch the banjo bolt on the top of the fuel filter is,
Thank you, Matt
I should know this as I've parted one too many cDSM's and sorted numerous 5 gallon buckets of fastners.....
If you haven't noticeed, there is roughly, 3 different sizes of bolts on the DSM's which all very in length. (With the exception of those used for the front rear crossmembers.) If memory serves me right, it is a 12mm with a 1.2 pitch ?
Guaranteed it's metric. Take it along to the hardware store and lay the two bolts so the threads overlap. If you pick a bolt that isn't the right size or pitch, you'll be able to tell.
-DaimlerChrysler Engineer :dsm: :laser:
