Enraged78
- 728
- 13
- Jul 17, 2002
South Windsor,
Connecticut
Finally! After three months of waiting for the snow to melt, my Garett T-25 decided to end its life about two weeks ago. I was waiting for warmer weather to put the 14b in, but with the T-25 making a horrible noise on boost, I decided to put it in now.
I started the whole deal on Friday. I worked with Triple Digit Motorsports to get a kit together for my car in a short amount of time. They did not have a prefab kit, so we put one together, and they had the whole setup ready in two days flat(!). I got all new lines, banjo bolts, gaskets, crush washers, 2.25" J-Pipe, and an Extreme XBC. I brought the car to my parents house Friday night, put the car up on stands, drained the oil, and coolant. I pulled the O2 sensor, upper and lower heat shelds, and dumped about an entire can of PB Blaster on every stud, nut, and bolt I was going to work on. Then I called it a day.
Saturday morning, I started to pull the turbo and manifold, along with everything else. I pulled the radiator and fans as one unit, and I labeled all my hoses and bolts with masking tape (no extra bolts this way). All bolts came free very easy thanks to the PB, and I found that one of my exhaust manifold studs was loose, and leaking. After looking at the T-25, I found that the shaft had a lot of play, and was moving laterally. I pulled the rest of the assembly out, and took the manifold, turbo, and everything else downstairs for porting.
Porting took up half of Saturday and Sunday. I used a 22K RPM die grinder with a Carbide steel bit to port the O2 sensor housing, Exhaust manifold and turbo. This was only my second attempt at porting, and I was told it came out very well. I removed the ring and step from the turbo to the manifold, and gasket-matched ported everything. (Be sure to use the new gaskets to match) This took about 10 hours for everything, including polishing the whole setup after porting. Then, I painted the J-pipe, heat shields, and my 1G BOV with black HI-Temp paint.
Monday (President's Day), everything went back together. In the middle of the blizzard. In my garage. God that sucked. A little word of advice: The oil return bolts on the 14B and the T-25 are different. Just use the bolts that hold the old oil feed line in place. They will fit. You should plug the old oil feed line, and use the one from the head anyway. When all was together, I let it idle for about 30 minuted, checked for leaks, then romped on it in neutral to see if it was building boost. (My car does this since I put the test pipe in. I'll see 10LBs if I goose it quick) Everything was good, so I closed it up and went for a spin in the blizzard.
14B vs. T-25: First off: No more boost spikes. Good. Second: Welcome to boost creep. Hehe. I have the XBC set to only 11 LBS, and it pulls so much harder than the T-25 did at 16 LBS, and the Garett spiked to 21 LBS! Once this turbo hits 5K, it's like someone just lets it loose. I'm getting about a 1.5 PSI spike, which isn't too bad. I plan on only running about 12-13 LBS until I upgrade my fuel system.
If anyone is planning a budget turbo upgrade on a 2G, GET THE 14B! It makes a world of difference if you take the time to do it right and port everything. Total project cost: Install kit: $290.00 XBC: $115.00. 14B with 10K on it: $200.00. Not bad for a little over $600.00 And I still have plenty of room for upping the boost. The 14b can handle up to about 21LBS if you have the fuel to feed it.
I hope this helps anyone planning the 14B install. I will upload pictures soon.
Thanks,
Matt.
Thanks,
Matt.
Anyhow Im not sure if swapping a 16g compressor is the best idea, but Im sure you can usually get what you put into 14b's when your done with them... Youll like it Im sure. I still dont understand how you can hit any amount of boost regardless of cat or not cat. There is typically no load on the motor while in nuetral and revving typically doesnt do anything (maybe 1psi for a half second or so)...
. jk, later fellas
