installing a 2g mas on a 1g
You need at least:
1.)2G MAS (ebay, DSMTrader)
2.)Wiring Harness (M&S Recycling)
3.)Turbo Inlet Pipe for 2G MAS on 1G Car(Dejon Tool)
4.)Fuel Pump
5.)Injectors
6.)SAFC
Wiring harness is the only tricky part:
*What you get is the plug from a 2G car cut off.
-You have to take the plug and make it fit to the 1G Wiring.
*What I did:
-Cut off the Plug Socket from my 1G MASS.
-Soldered the 2G wires to the plug socket. (Used diagram from VFAQ. Pretty confusing the way it's written in the VFAQ, but I finally got it)
-Now the 2G Plug plugs into the 2G MAS, and then the car plugs into the socket that you just soldered onto the wires.
Everything else is pretty simple.
Thanx,
DeathBeast
This is mine:
Thanx,
DeathBeast
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
