Clutch Pedal Adjustment??
95mitsugsx
52
Sep 2, 2002
Does any one know how to adjust the clutch pedal throw on a 2G AWD. My clutch pulls right off the floor and sometimes even grinds into gears when shikfting hard. I saw on VFAQ and it has an article on a 1G clutch adjustment. any advice is appreciated.
There's a rod towards the top of the pedal, loosen the bolt that should be right up against the little plate up there, and twist the rod towards the firewall to get a higher engagement/disengagement point, but don't twist it too far or you may run into problems like the clutch not disengaging fully and causing a slipping-type effect(engine will rev high and car won't move almost like in neutral, but in gear).
