1G head flow numbers and intake designs...long
Polk
91
May 9, 2002
I have been doing a lot of flow bench data on different intake designs over the past few days and this is what I have come up with so far.
Now the test subject was a totally stock 1G head. It still has the factory valve job and valves.
Here are the numbers that I have collected as of now.
Stock head with no intake and a ¾” radius entry. #3 intake runner. As you can see these are a good flowing head to begin with.
Lift CFM
.050 48.91
.100 94.21
.150 139.62
.200 181.24
.250 216.94
.300 241.11
.350 261.52
.400 271.14
.450 280.45
Stock head with a stock intake. No T.B. with a ¾” radius entry. #3 intake runner. You can see not only does the stock intake kill the upper lift flow like everyone knew, but it hurts low lift flow as well.
Lift CFM
.050 33.75
.100 88.70
.150 128.18
.200 169.87
.250 202.57
.300 223.95
.350 238.73
.400 245.79
.450 252.65
Stock head with a 4” tapered runner sheet metal intake and a 240 cubic inch plenum. No T.B. with a ¾” radius entry, and a 60mm opening. #3 intake runner. You can see were the stock intake out flows it until the .200 lift mark. It will hurt the lower end a bit, but make up for it in the mid to upper RPM range.
Lift CFM
.050 32.02
.100 76.92
.150 128.41
.200 169.54
.250 205.36
.300 233.91
.350 254.90
.400 267.98
.450 274.29
Stock head with 6” tapered runner sheet metal intake and a 240 cubic inch plenum. No T.B. with a ¾” radius entry, and a 60mm opening. #3 intake runner. You can see were this one kicks the crap out of both intakes tested in every lift. Makes for killer low end and top end charge.
Lift CFM
.050 45.28
.100 91.17
.150 140.12
.200 183.17
.250 221.39
.300 243.46
.350 261.52
.400 270.10
.450 278.41
Stock head with 4” tapered runner sheet metal intake and a 540 cubic inch plenum. No T.B. with a ¾” radius entry, and a 60mm opening. #3 intake runner. Now this test was done to see if a bigger plenum does have any effect on non force induction application. Remember the flow bench draws air threw the intake, not forcing air into it. That test will come later on to see the results as well. You can see were the two shorter runner intakes flow a lot alike.
Lift CFM
.050 35.12
.100 61.31
.150 121.32
.200 167.51
.250 205.36
.300 233.91
.350 254.90
.400 267.98
.450 280.45
Stock head with 6” nontapered runner sheet metal intake a 240 cubic inch plenum. No T.B. with a ¾” radius entry, and a 60mm opening. #3 intake runner. Now notice how not having a tapered runner does not fill the cylinder as well. It does out do the stock intake but not well enough.
Lift CFM
.050 35.40
.100 89.91
.150 128.62
.200 170.88
.250 205.36
.300 231.46
.350 252.65
.400 263.69
.450 270.10
I hope to do a complete stage test as above in the next few weeks. I will start with a level 1 head with stock sized valves and go up from there with all the same test shown as above. From what I have gathered so far. I do believe that a aftermarket intake even on a stock car that is tuned properly (intake) to the combination will make more power. Now I am not trying to say go out and buy something like this first, but I do see were it will help out long before a ported race head. I can see one thing for sure. If a stock intake hurts flow that bad on a stock head…..what is it going to do on one that has been worked over?
I would like to flow a stock Extrude Hone intake to compare it as well. If any of you guys have one and are not using it yet I would like to borrow it for a day. I will be happy to pay shipping to and from my shop.
All the test have been performed on a JKM 600 flow bench on the same day under the same conditions. Each intake tested had every runner (except #3) blocked off between the intake and head so that no bleed off air was involved. All vacuum ports blocked and injector hole plugged as well.
Now as you can see what time it is by my post. I am tired and heading for home.
Hope some of you learn something from this.
Polk
are the #'s for "Stock head with a 4” tapered runner sheet metal intake and a 240 cubic inch plenum" correct? they are exactly the same as the stock manifold..
Sorry for that. It was late when I posted the numbers. It is fixed now.
As for the 2G heads I will be doing some test on them as well. It may be a couple of weeks out on them.
Polk
OK everybody, I have some more flow data on the 1G head. Now this one is pretty much a race ported head. I will start off with everything that was done with the stock one has been done here as well. Example: ¾” radius entry. #3 intake runner and so on. All tested @ 28” of water
Now I want everyone to realize one thing…..WE ARE NOT RACING FLOW-BENCHES…. The numbers that I am posting just show the characteristics of different manifolds and how they react in different applications. Just because this intake shows to outdo another does not mean that it will be right with your combination. Many of DSMers have ran good times with stock intakes. Marco at Magnus ran a very low ten second pass with a stock head. But one thing you have to remember.. Efficiency means power.
4G63 level 4 head. 1mm over valves, no intake, ¾ radius entry
Lift CFM
.050 60.38
.100 106.30
.150 161.19
.200 187.97
.250 241.11
.300 270.10
.350 298.19
.400 309.45
.450 320.31
Now I kept on flowing it past this lift to just see what this thing could do.
.500 334.25
.550 345.98
.600 357.32
.650 365.21
.700 374.46 Now that should give some of the V8 guys nightmares.
Same head with 6” tapered runner 240 cubic inch plenum
Lift CFM
.050 55.46
.100 104.67
.150 152.47
.200 187.97
.250 236.33
.300 265.85
.350 288.47
.400 301.99
.450 313.11
Same head with 4” tapered runner 240 cubic inch plenum
Lift CFM
.050 58.46
.100 101.35
.150 147.94
.200 210.84
.250 226.48
.300 259.33
.350 282.48
.400 298.19
.450 307.60
Same head with stock intake
Lift CFM
.050 55.46
.100 101.35
.150 144.43
.200 189.94
.250 218.80
.300 243.46
.350 263.69
.400 270.10
.450 280.45
Same head with Cyclone intake. Now there will be two different numbers on this one. One were both short and long runners are open and one with just the long one in use.
Both runner in use.
Lift CFM
.050 52.29
.100 98.96
.150 142.05
.200 180.29
.250 210.84
.300 241.11
.350 261.52
.400 270.10
.450 280.45
Long runner only
Lift CFM
.050 52.29
.100 94.24
.150 133.36
.200 162.25
.250 183.12
.300 193.94
.350 205.36
.400 210.84
.450 213.53
Polk
28" of water is equal to 1.01 psi. In order to have a bench to flow that kind of psi you would need one that could flow 415" of water to get 15 psi.
Polk
it looks as if the head work was much more effective as the stock head with an after market intake didnt respond nearly as well as the level 4 head with the stock intake did. does this mean while my head is off to get it done and use the money that i had for an intake instead to pay the head bill? it offers more gain over a much wider spectrum. what are the cost differences? which one is a better bang per buck?
Is it correct that the cyclone flowed less? If so then what is the advantage of this intake over stock?
Higher volumetric efficiency at lower rpms (more low end torque) since one of the runners is closed for each cylinder, which increases the port velocity. This is the advantage at a very small if even significant drop in high end flow...per the numbers.
I know this has been posted before, sorry for the repeat.
Ken Young
