Basic MAFT Questions [merged] GM MAF Translator
gotboost55
132
Jan 14, 2003
What is it?
What does it do?
Where does it go?
Where does the xxxx color wire go?
Can I vent with a MAFT?
What MAF can I use?
Can I use a 2g MAFT with a 1g?
Can I use a 1g MAFT with a 2g?
Sorry guys !but am not really sure about this one.What does the MAFT really do and is it a good buy?thanks
Its what I'll be running when my car comes out of storage:D
here's some links for you for some info,
http://www.teamnabr.com/ubbpub/ultimatebb.php?ubb=get_topic;f=10;t=000324
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=90266&highlight=MAFT
http://144mph.com/gm.htm
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=73517&highlight=GM*+MAS
http://www.dejontool.com/Fuel.htm
Try searching, their is a lot of usefull info on this subject.
What the GM MAS does is first, you get rid of the crappy, low-flowing-fuel-cutting-hunk-of-crap 1G MAS. It flows more efficient, you can hear the spool a lot better. You can choose to set it up a couple different ways as well. You can put it in the stock location, and let the BOV recerculate, or you can put it right between the intake manifold and the BOV which will let you vent your BOV to the atmosphere, you will be able to hear it quite well. However, you will need hard IC piping to vent to the atmosphere. I believe the GM MAFT conversion can support in the range of 450hp? With the translator you can adjust your fuel settings as well to cope with more fuel coming in(bigger injectors). Hope that helps a bit.
I installed the MAFT blow thru but I don't know where the small hose from the boost control solenoid to the snorkel goes now or the larger hose from the snorkel to that part back by the fire wall. where do these go now.
I dont believe it could hurt. I know the GM maf is a lot less restrictive than stock, but somebody else might want to put in their $.02
I have heard the 1g mas is very restrictive, often 1g's convert to 2g mas or the gm mas, I want to convert to gm mas just because I want to vent to the atmosphere without letting puffs unburnt fuel out the ass of my car and so I can pass emissions while venting! So I definitley think it's worth it. I heard it's all just plug and play too. If I had the money I would have already done it. Good luck!
i say yes, i am completely stock right now but will probly have an exhaust by the time i get it hooked up. i still have to buy the translator. anything that improves performance is worth it, you will spool up quicker. you may have to tinker with the settings to get it to idle and drive right, but it wouldnt be any harder than generically setting up a safc to prepare for tuning
I know that the one wire tap goes to your CAS to a black wire. But there are two so which one do I tap into here? Is there anyway to identify which wire to tap into to?
Does the wire got a white stripe on it? I know where its located but there are two there. Its on the CAS
THANKS!!!!!!:thumb: :thumb: :thumb: :thumb:
Has anyone ever installed this on a lightly modded car? I do not have any fuel control or tuning devices yet but I was wondering if you could just run it without adjusting fuel trims. I just purchased the setup and hopefully will put it on next week. I know I probably should have bought a turbo that actually makes some power before buying this but someone slid on ice into my car. :mad: Only a little dent but I get 600, so thats going toward the 50 trim :thumb:
OMG bro your car is freaking amazing looking!!!! If only I had money and time to find and buy one. Anyway like stated above just zero everything out and get a logging device to monitor everything. But look at it this way, its better to get supporitng mods rather than run the turbo without them and risk messing somethintg up.
Yes I realize that a maft in not needed nor a supporting mod but it makes tunning easier.
Does anybody have the GM part numbers for the 3" MAF and Translator?
Or wait, the translator isn't made by GM, is it? In that case, just the GM part number for the MAF.
Thanks
The GM MAFT (Translator): http://www.fullthrottlespeed.com
Additional info: http://www.dsmtuners.com/forums/showthread.php?s=&threadid=35397&perpage=25&pagenumber=1
3" mafs, gm part #25180303 (213-352 on acdelco.com)
2003 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = J
2003 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = J
2003 BUICK RENDEZVOUS V6 3.4L 207cid GAS FI N Engine VIN = E
2003 CHEVROLET ASTRO V6 4.3L 262cid GAS FI N Engine VIN = X
2003 CHEVROLET IMPALA V6 3.4L 207cid GAS FI N Engine VIN = E
2003 CHEVROLET MALIBU LS V6 3.1L 189cid GAS FI N Engine VIN = J
2003 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = J
2003 CHEVROLET MONTE CARLO LS V6 3.4L 207cid GAS FI N Engine VIN = E
2003 CHEVROLET S10 BLAZER V6 4.3L 262cid GAS FI N Engine VIN = X
2003 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = X
2003 CHEVROLET VENTURE V6 3.4L 207cid GAS FI N Engine VIN = E
2003 GMC SAFARI V6 4.3L 262cid GAS FI N Engine VIN = X
2003 OLDSMOBILE ALERO V6 3.4L 207cid GAS FI N Engine VIN = E
2003 OLDSMOBILE SILHOUETTE V6 3.4L 207cid GAS FI N Engine VIN = E
2003 PONTIAC AZTEK GT V6 3.4L 207cid GAS FI N Engine VIN = E
2003 PONTIAC AZTEK V6 3.4L 207cid GAS FI N Engine VIN = E
2003 PONTIAC GRAND AM V6 3.4L 207cid GAS FI N Engine VIN = E
2003 PONTIAC MONTANA V6 3.4L 207cid GAS FI N Engine VIN = E
2002 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = J
2002 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = J
2002 BUICK RENDEZVOUS V6 3.4L 207cid GAS FI N Engine VIN = E
2002 CHEVROLET IMPALA V6 3.4L 207cid GAS FI N Engine VIN = E
2002 CHEVROLET MALIBU LS V6 3.1L 189cid GAS FI N Engine VIN = J
2002 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = J
2002 CHEVROLET S10 BLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
2002 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = W
2002 CHEVROLET VENTURE V6 3.4L 207cid GAS FI N Engine VIN = E
2002 GMC S15 SONOMA V6 4.3L 262cid GAS FI N Engine VIN = W
2002 OLDSMOBILE ALERO V6 3.4L 207cid GAS FI N Engine VIN = E
2002 OLDSMOBILE AURORA V6 3.5L 214cid GAS FI N Engine VIN = H
2002 OLDSMOBILE INTRIGUE V6 3.5L 214cid GAS FI N Engine VIN = H
2002 OLDSMOBILE SILHOUETTE V6 3.4L 207cid GAS FI N Engine VIN = E
2002 PONTIAC AZTEK GT V6 3.4L 207cid GAS FI N Engine VIN = E
2002 PONTIAC AZTEK V6 3.4L 207cid GAS FI N Engine VIN = E
2002 PONTIAC GRAND AM V6 3.4L 207cid GAS FI N Engine VIN = E
2002 PONTIAC GRAND PRIX V6 3.1L 189cid GAS FI N Engine VIN = J
2002 PONTIAC MONTANA V6 3.4L 207cid GAS FI N Engine VIN = E
2001 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = J
2001 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = J
2001 CHEVROLET ASTRO V6 4.3L 262cid GAS FI N Engine VIN = W
2001 CHEVROLET IMPALA V6 3.4L 207cid GAS FI N Engine VIN = E
2001 CHEVROLET LUMINA V6 3.1L 189cid GAS FI N Engine VIN = J
2001 CHEVROLET MALIBU LS V6 3.1L 189cid GAS FI N Engine VIN = J
2001 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = J
2001 CHEVROLET MONTE CARLO LS V6 3.4L 207cid GAS FI N Engine VIN = E
2001 CHEVROLET S10 BLAZER TRAILBLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
2001 CHEVROLET S10 BLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
2001 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = W
2001 GMC S15 JIMMY ENVOY V6 4.3L 262cid GAS FI N Engine VIN = W
2001 GMC S15 JIMMY V6 4.3L 262cid GAS FI N Engine VIN = W
2001 GMC S15 SONOMA V6 4.3L 262cid GAS FI N Engine VIN = W
2001 GMC SAFARI V6 4.3L 262cid GAS FI N Engine VIN = W
2001 OLDSMOBILE ALERO V6 3.4L 207cid GAS FI N Engine VIN = E
2001 OLDSMOBILE AURORA V6 3.5L 214cid GAS FI N Engine VIN = H
2001 OLDSMOBILE BRAVADA V6 4.3L 262cid GAS FI N Engine VIN = W
2001 OLDSMOBILE INTRIGUE V6 3.5L 214cid GAS FI N Engine VIN = H
2001 OLDSMOBILE SILHOUETTE V6 3.4L 207cid GAS FI N Engine VIN = E
2001 PONTIAC AZTEK GT V6 3.4L 207cid GAS FI N Engine VIN = E
2001 PONTIAC AZTEK V6 3.4L 207cid GAS FI N Engine VIN = E
2001 PONTIAC GRAND AM V6 3.4L 207cid GAS FI N Engine VIN = E
2001 PONTIAC GRAND PRIX V6 3.1L 189cid GAS FI N Engine VIN = J
2001 PONTIAC MONTANA V6 3.4L 207cid GAS FI N Engine VIN = E
2000 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = J
2000 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = J
2000 CHEVROLET ASTRO V6 4.3L 262cid GAS FI N Engine VIN = W
2000 CHEVROLET IMPALA V6 3.4L 207cid GAS FI N Engine VIN = E
2000 CHEVROLET LUMINA V6 3.1L 189cid GAS FI N Engine VIN = J
2000 CHEVROLET MALIBU LS V6 3.1L 189cid GAS FI N Engine VIN = J
2000 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = J
2000 CHEVROLET MONTE CARLO LS V6 3.4L 207cid GAS FI N Engine VIN = E
2000 CHEVROLET S10 BLAZER TRAILBLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
2000 CHEVROLET S10 BLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
2000 CHEVROLET VENTURE V6 3.4L 207cid GAS FI N Engine VIN = E
2000 GMC S15 JIMMY ENVOY V6 4.3L 262cid GAS FI N Engine VIN = W
2000 GMC S15 JIMMY V6 4.3L 262cid GAS FI N Engine VIN = W
2000 GMC S15 SONOMA V6 4.3L 262cid GAS FI N Engine VIN = W
2000 GMC SAFARI V6 4.3L 262cid GAS FI N Engine VIN = W
2000 OLDSMOBILE ALERO V6 3.4L 207cid GAS FI N Engine VIN = E
2000 OLDSMOBILE BRAVADA V6 4.3L 262cid GAS FI N Engine VIN = W
2000 OLDSMOBILE INTRIGUE V6 3.5L 214cid GAS FI N Engine VIN = H
2000 OLDSMOBILE SILHOUETTE V6 3.4L 207cid GAS FI N Engine VIN = E
2000 PONTIAC GRAND AM V6 3.4L 207cid GAS FI N Engine VIN = E
2000 PONTIAC GRAND PRIX V6 3.1L 189cid GAS FI N Engine VIN = J
2000 PONTIAC MONTANA V6 3.4L 207cid GAS FI N Engine VIN = E
1999 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = M
1999 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = M
1999 CHEVROLET ASTRO V6 4.3L 262cid GAS FI N Engine VIN = W
1999 CHEVROLET LUMINA V6 3.1L 189cid GAS FI N Engine VIN = M
1999 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = J
1999 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = M
1999 CHEVROLET MONTE CARLO V6 3.1L 189cid GAS FI N Engine VIN = M
1999 CHEVROLET S10 BLAZER TRAILBLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
1999 CHEVROLET S10 BLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
1999 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = W
1999 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = X
1999 CHEVROLET VENTURE V6 3.4L 207cid GAS FI N Engine VIN = E
1999 GMC S15 JIMMY V6 4.3L 262cid GAS FI N Engine VIN = W
1999 GMC S15 SONOMA V6 4.3L 262cid GAS FI N Engine VIN = W
1999 GMC S15 SONOMA V6 4.3L 262cid GAS FI N Engine VIN = X
1999 GMC SAFARI V6 4.3L 262cid GAS FI N Engine VIN = W
1999 OLDSMOBILE ALERO V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1999 OLDSMOBILE BRAVADA V6 4.3L 262cid GAS FI N Engine VIN = W
1999 OLDSMOBILE CUTLASS V6 3.1L 189cid GAS FI N Engine VIN = M
1999 OLDSMOBILE INTRIGUE V6 3.5L 214cid GAS FI N Engine VIN = H
1999 OLDSMOBILE SILHOUETTE V6 3.4L 207cid GAS FI N Engine VIN = E
1999 PONTIAC GRAND AM V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1999 PONTIAC GRAND PRIX V6 3.1L 189cid GAS FI N Engine VIN = M
1999 PONTIAC MONTANA V6 3.4L 207cid GAS FI N Engine VIN = E
1998 BUICK CENTURY CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 BUICK CENTURY LIMITED V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 BUICK SKYLARK V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 CHEVROLET ASTRO V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 CHEVROLET LUMINA LTZ V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 CHEVROLET LUMINA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 CHEVROLET MALIBU LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 CHEVROLET MALIBU V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 CHEVROLET MONTE CARLO LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 CHEVROLET S10 BLAZER V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 CHEVROLET S10 PICKUP V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 CHEVROLET S10 PICKUP V6 LF6 4.3L 262cid GAS FI N Engine VIN = X
1998 GMC S15 JIMMY V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 GMC S15 JIMMY ENVOY V6 4.3L 262cid GAS FI N Engine VIN = W
1998 GMC S15 SONOMA V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 GMC S15 SONOMA V6 LF6 4.3L 262cid GAS FI N Engine VIN = X
1998 GMC SAFARI V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 OLDSMOBILE ACHIEVA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 OLDSMOBILE BRAVADA REGIONAL V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 OLDSMOBILE BRAVADA V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 OLDSMOBILE CUTLASS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 OLDSMOBILE SILHOUETTE V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1998 PONTIAC GRAND AM GT V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 PONTIAC GRAND AM SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 PONTIAC GRAND AM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 PONTIAC GRAND PRIX SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 PONTIAC GRAND PRIX V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 PONTIAC TRANS SPORT MONTANA V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1998 PONTIAC TRANS SPORT V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1997 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = M
1997 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = M
1997 BUICK SKYLARK CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 BUICK SKYLARK GRAN SPORT V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 BUICK SKYLARK LIMITED V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 CHEVROLET ASTRO V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 CHEVROLET LUMINA LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 CHEVROLET LUMINA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 CHEVROLET LUMINA LTZ V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1997 CHEVROLET MALIBU LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 CHEVROLET MALIBU V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 CHEVROLET MONTE CARLO LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 CHEVROLET MONTE CARLO Z34 V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1997 CHEVROLET S10 BLAZER V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 CHEVROLET S10 PICKUP V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 CHEVROLET S10 PICKUP V6 LF6 4.3L 262cid GAS FI N Engine VIN = X
1997 CHEVROLET VENTURE V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1997 GMC S15 JIMMY V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 GMC S15 SONOMA V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 GMC S15 SONOMA V6 LF6 4.3L 262cid GAS FI N Engine VIN = X
1997 GMC SAFARI XT V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 OLDSMOBILE ACHIEVA SC V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 OLDSMOBILE ACHIEVA SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 OLDSMOBILE BRAVADA V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 OLDSMOBILE CUTLASS GLS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 OLDSMOBILE CUTLASS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 OLDSMOBILE CUTLASS SUPREME SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 OLDSMOBILE SILHOUETTE V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1997 PONTIAC GRAND AM GT V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 PONTIAC GRAND AM SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 PONTIAC GRAND PRIX SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 BUICK REGAL CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 BUICK REGAL GRAN SPORT V6 3.1L 189cid GAS FI N Engine VIN = M
1996 BUICK ROADMASTER LIMITED V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 BUICK ROADMASTER LIMITED WAGON V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 BUICK ROADMASTER V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 BUICK SKYLARK CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 BUICK SKYLARK GRAN SPORT V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 BUICK SKYLARK LIMITED V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CADILLAC FLEETWOOD BROUGHAM V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 CADILLAC FLEETWOOD V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 CHEVROLET ASTRO V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1996 CHEVROLET BERETTA Z26 V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CHEVROLET BERETTA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CHEVROLET CAPRICE CLASSIC V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 CHEVROLET CAPRICE CLASSIC V8 4.3L 265cid GAS FI N Engine VIN = W
1996 CHEVROLET CORSICA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CHEVROLET IMPALA SS V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 CHEVROLET LUMINA LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CHEVROLET LUMINA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CHEVROLET LUMINA LS V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1996 CHEVROLET LUMINA APV V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1996 CHEVROLET MONTE CARLO LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CHEVROLET MONTE CARLO Z34 V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1996 CHEVROLET S10 BLAZER V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1996 CHEVROLET S10 PICKUP V6 LF6 4.3L 262cid GAS FI N Engine VIN = X
1996 GMC S15 JIMMY V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1996 GMC S15 SONOMA V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1996 GMC S15 SONOMA V6 LF6 4.3L 262cid GAS FI N Engine VIN = X
1996 GMC SAFARI XT V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1996 OLDSMOBILE ACHIEVA SC V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 OLDSMOBILE ACHIEVA SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 OLDSMOBILE BRAVADA V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1996 OLDSMOBILE CUTLASS SUPREME SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 OLDSMOBILE CUTLASS SUPREME SL V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1996 OLDSMOBILE SILHOUETTE V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1996 PONTIAC GRAND AM GT V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 PONTIAC GRAND AM SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 PONTIAC GRAND PRIX SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 PONTIAC GRAND PRIX GT V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1996 PONTIAC GRAND PRIX GTP V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1996 PONTIAC TRANS SPORT V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1995 BUICK REGAL CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 BUICK REGAL GRAN SPORT V6 3.1L 189cid GAS FI N Engine VIN = M
1995 BUICK ROADMASTER ESTATE V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 BUICK ROADMASTER LIMITED V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 BUICK ROADMASTER V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 CADILLAC FLEETWOOD BROUGHAM V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 CADILLAC FLEETWOOD V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 CHEVROLET CAPRICE CLASSIC V8 4.3L 265cid GAS FI N Engine VIN = W
1995 CHEVROLET IMPALA SS V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 CHEVROLET LUMINA LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 CHEVROLET LUMINA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 CHEVROLET LUMINA LS V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1995 CHEVROLET MONTE CARLO LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 CHEVROLET MONTE CARLO Z34 V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1995 OLDSMOBILE CUTLASS SUPREME SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 OLDSMOBILE CUTLASS SUPREME V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 OLDSMOBILE CUTLASS SUPREME SL V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1995 OLDSMOBILE CUTLASS SUPREME V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1995 PONTIAC GRAND PRIX SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 PONTIAC GRAND PRIX GT V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1995 PONTIAC GRAND PRIX GTP V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1994 BUICK REGAL CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1994 BUICK ROADMASTER ESTATE V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1994 BUICK ROADMASTER LIMITED V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1994 BUICK ROADMASTER V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1994 CHEVROLET CAPRICE CLASSIC V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1994 CHEVROLET CAPRICE LS V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1994 CHEVROLET CAPRICE CLASSIC V8 4.3L 265cid GAS FI N Engine VIN = W
1994 CHEVROLET CAPRICE CLASSIC LS V8 4.3L 265cid GAS FI N Engine VIN = W
1994 CHEVROLET IMPALA SS V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1994 CHEVROLET LUMINA EURO V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1994 OLDSMOBILE CUTLASS CIERA SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1994 OLDSMOBILE CUTLASS SUPREME S V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1994 OLDSMOBILE CUTLASS SUPREME V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1994 OLDSMOBILE CUTLASS SUPREME S V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1994 OLDSMOBILE CUTLASS SUPREME V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1994 PONTIAC GRAND PRIX SE V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1994 PONTIAC GRAND PRIX SE V6 3.1L 189cid GAS FI N Engine VIN = M
3.5" mafs, gm part #25179711 (213-353 acdelco.com)
2002 CHEVROLET CAMARO SS V8 5.7L 350cid GAS FI N Engine VIN = G
2002 CHEVROLET CAMARO Z28 V8 5.7L 350cid GAS FI N Engine VIN = G
2002 CHEVROLET EXPRESS 1500 V6 4.3L 262cid GAS FI N Engine VIN = W
2002 CHEVROLET EXPRESS 1500 V8 5.0L 305cid GAS FI N Engine VIN = M
2002 CHEVROLET EXPRESS 1500 V8 5.7L 350cid GAS FI N Engine VIN = R
2002 CHEVROLET EXPRESS 2500 V6 4.3L 262cid GAS FI N Engine VIN = W
2002 CHEVROLET EXPRESS 2500 V8 5.0L 305cid GAS FI N Engine VIN = M
2002 CHEVROLET EXPRESS 2500 V8 5.7L 350cid GAS FI N Engine VIN = R
2002 CHEVROLET EXPRESS 3500 V8 5.7L 350cid GAS FI N Engine VIN = R
2002 CHEVROLET EXPRESS 3500 V8 8.1L 496cid GAS FI N Engine VIN = G
2002 GMC SAVANA 1500 V6 4.3L 262cid GAS FI N Engine VIN = W
2002 GMC SAVANA 1500 V8 5.0L 305cid GAS FI N Engine VIN = M
2002 GMC SAVANA 1500 V8 5.7L 350cid GAS FI N Engine VIN = R
2002 GMC SAVANA 2500 V6 4.3L 262cid GAS FI N Engine VIN = W
2002 GMC SAVANA 2500 V8 5.0L 305cid GAS FI N Engine VIN = M
2002 GMC SAVANA 2500 V8 5.7L 350cid GAS FI N Engine VIN = R
2002 GMC SAVANA 3500 V8 5.7L 350cid GAS FI N Engine VIN = R
2002 GMC SAVANA 3500 V8 8.1L 496cid GAS FI N Engine VIN = G
2002 PONTIAC FIREBIRD FORMULA V8 5.7L 350cid GAS FI N Engine VIN = G
2002 PONTIAC FIREBIRD TRANS AM V8 5.7L 350cid GAS FI N Engine VIN = G
2001 CHEVROLET CAMARO SS V8 5.7L 350cid GAS FI N Engine VIN = G
2001 CHEVROLET CAMARO Z28 V8 5.7L 350cid GAS FI N Engine VIN = G
2001 CHEVROLET EXPRESS 1500 V6 4.3L 262cid GAS FI N Engine VIN = W
2001 CHEVROLET EXPRESS 1500 V8 5.0L 305cid GAS FI N Engine VIN = M
2001 CHEVROLET EXPRESS 1500 V8 5.7L 350cid GAS FI N Engine VIN = R
2001 CHEVROLET EXPRESS 2500 V6 4.3L 262cid GAS FI N Engine VIN = W
2001 CHEVROLET EXPRESS 2500 V8 5.0L 305cid GAS FI N Engine VIN = M
2001 CHEVROLET EXPRESS 2500 V8 5.7L 350cid GAS FI N Engine VIN = R
2001 CHEVROLET EXPRESS 3500 V8 5.7L 350cid GAS FI N Engine VIN = R
2001 CHEVROLET EXPRESS 3500 V8 8.1L 496cid GAS FI N Engine VIN = G
2001 GMC SAVANA 1500 V6 4.3L 262cid GAS FI N Engine VIN = W
2001 GMC SAVANA 1500 V8 5.0L 305cid GAS FI N Engine VIN = M
2001 GMC SAVANA 1500 V8 5.7L 350cid GAS FI N Engine VIN = R
2001 GMC SAVANA 2500 V6 4.3L 262cid GAS FI N Engine VIN = W
2001 GMC SAVANA 2500 V8 5.0L 305cid GAS FI N Engine VIN = M
2001 GMC SAVANA 2500 V8 5.7L 350cid GAS FI N Engine VIN = R
2001 GMC SAVANA 3500 V8 5.7L 350cid GAS FI N Engine VIN = R
2001 GMC SAVANA 3500 V8 8.1L 496cid GAS FI N Engine VIN = G
2001 PONTIAC FIREBIRD FORMULA V8 5.7L 350cid GAS FI N Engine VIN = G
2001 PONTIAC FIREBIRD TRANS AM V8 5.7L 350cid GAS FI N Engine VIN = G
2000 CHEVROLET CAMARO SS V8 5.7L 350cid GAS FI N Engine VIN = G
2000 CHEVROLET CAMARO Z28 V8 5.7L 350cid GAS FI N Engine VIN = G
2000 CHEVROLET CORVETTE V8 5.7L 350cid GAS FI N Engine VIN = G
2000 CHEVROLET KODIAK 4X2 C 2WD V8 7.4L G MFI Engine VIN = D
2000 CHEVROLET MD BUS CHASSIS V8 7.4L G MFI Engine VIN = D
2000 GMC MD BUS CHASSIS V8 7.4L G MFI Engine VIN = D
2000 GMC TOPKICK 4X2 C 2WD V8 7.4L G MFI Engine VIN = D
2000 GMC TOPKICK 6X4 C 2WD V8 7.4L G MFI Engine VIN = D
2000 PONTIAC FIREBIRD FORMULA V8 5.7L 350cid GAS FI N Engine VIN = G
1999 CHEVROLET CAMARO SS V8 5.7L 350cid GAS FI N Engine VIN = G
1999 CHEVROLET CAMARO Z28 V8 5.7L 350cid GAS FI N Engine VIN = G
1999 CHEVROLET CORVETTE V8 5.7L 350cid GAS FI N Engine VIN = G
1999 CHEVROLET KODIAK 4X2 C 2WD V8 7.4L G MFI Engine VIN = D
1999 CHEVROLET MD BUS CHASSIS V8 7.4L G MFI Engine VIN = D
1999 CHEVROLET P30 VAN V6 4.3L 262cid GAS FI N Engine VIN = W
1999 CHEVROLET P30 VAN V8 5.7L 350cid GAS FI N Engine VIN = R
1999 CHEVROLET P30 VAN V8 7.4L 454cid GAS FI N Engine VIN = B
1999 CHEVROLET P30 VAN V8 7.4L 454cid GAS FI N Engine VIN = J
1999 GMC MD BUS CHASSIS V8 7.4L G MFI Engine VIN = D
1999 GMC P35/P3500 VAN V6 4.3L 262cid GAS FI N Engine VIN = W
1999 GMC P35/P3500 VAN V8 5.7L 350cid GAS FI N Engine VIN = R
1999 GMC P35/P3500 VAN V8 7.4L 454cid GAS FI N Engine VIN = B
1999 GMC P35/P3500 VAN V8 7.4L 454cid GAS FI N Engine VIN = J
1999 GMC TOPKICK 4X2 C 2WD V8 7.4L G MFI Engine VIN = D
1999 GMC TOPKICK 6X4 C 2WD V8 7.4L G MFI Engine VIN = D
1999 PONTIAC FIREBIRD FORMULA V8 5.7L 350cid GAS FI N Engine VIN = G
1999 PONTIAC FIREBIRD TRANS AM V8 5.7L 350cid GAS FI N Engine VIN = G
1998 CHEVROLET CAMARO SS V8 LS1 5.7L 350cid GAS FI N Engine VIN = G
1998 CHEVROLET CAMARO Z28 V8 LS1 5.7L 350cid GAS FI N Engine VIN = G
1998 CHEVROLET CORVETTE V8 LS1 5.7L 350cid GAS FI N Engine VIN = G
1998 CHEVROLET P30 VAN V6 4.3L 262cid GAS FI N Engine VIN = W
1998 CHEVROLET P30 VAN V8 5.7L 350cid GAS FI N Engine VIN = R
1998 CHEVROLET P30 VAN V8 7.4L 454cid GAS FI N Engine VIN = B
1998 GMC P35/P3500 VAN V6 4.3L 262cid GAS FI N Engine VIN = W
1998 GMC P35/P3500 VAN V8 5.7L 350cid GAS FI N Engine VIN = R
1998 GMC P35/P3500 VAN V8 7.4L 454cid GAS FI N Engine VIN = B
1998 GMC P35/P3500 VAN V8 7.4L 454cid GAS FI N Engine VIN = J
1998 PONTIAC FIREBIRD FIREHAWK V8 LS1 5.7L 350cid GAS FI N Engine VIN = G
1998 PONTIAC FIREBIRD FORMULA V8 LS1 5.7L 350cid GAS FI N Engine VIN = G
1998 PONTIAC FIREBIRD TRANS AM V8 LS1 5.7L 350cid GAS FI N Engine VIN = G
1997 CHEVROLET CORVETTE V8 LS1 5.7L 350cid GAS FI N Engine VIN = G
1997 CHEVROLET MD ISUZU TRUCK TILTMAST Any
1997 GMC MD DUTY ISUZU TRUCK FORWARD Any
You need the the MAFT no matter what in order to get the 3in gm mas to work on our cars. An safc will not take the place of the translator. From what I have read the maft and gm mas are just plug and play but I have also read that some people need the safc to get the car to run at optimum performance and to idel correctly.
Originally posted by DSHIZNIT
If i had a AFC would i need the MAFT translator
AFC is an Air and Fuel controller. It intercepts signal from the MAS and fools the ECU into adjusting fuel flow to the injectos, by sending a modified signal, based on settings of MAFT.
Read the link: http://www.dsmtuners.com/forums/showthread.php?s=&threadid=35397&perpage=25&pagenumber=1
AFC is needed for further adjustment precision. To "fine tune".
I was just curious, would a MAFT and a GM MAF make a difference on a pretty mild vehicle (2.5" Turbo back/test-pipe, Intake, fuel pump)?
I mean, you would be freeing up any restrictions in the intake charge, and spool time should decrease... So, would it make a noticable diference?
I know people say that the 1G MAF flows X-amount, and on a basically stock engine you wont need the CFM flow of a GM MAF, but then again, the stock air cleaner flows more CFM than you need, and a K&N still makes a difference.....
I know some of this sounds dumb... Why would a guy with a stock car want a GM MAFT when he can get other proven parts? Well, truth is, my buddy has a 240sx with a vented BOV, and the ricer in me wants a vented BOV too :(
Also, Im changineg my IC pipes, and if I dont eat for a week I can get a GM MAFT kit also, so I need to know which IC pipe to buy.
Thanks :laser:
yes , you will feel a considerable difference by changing over to the gm maft setup, but try not to run stock injectors on the car when you get it , try to get at least 550cc. the gm maf will outflow a 2g mas and it will help on your spoolup time and personally i like it better than 2g mass. with the amount of mods you have on your car you should be fine, i would just wait and save your money for a front mount intercooler cuz if you just buy an upper pipe that would be money you would have towards your front mount and slowboy racing sells their intercooler kit setup for gm maf now if you want to take that into consideration , if you have any questions about it , just pm me or im me on aol my sn is sergiosdsm
I was just wondering what are all the reasons to use a GM MAF. If I install it on my intake tube instead of UICP can I still vent to atmosphere? Also can I use that and an AIR/FUEL gauge with no AFC to tune? Thanks for your input.
No you can't vent with it on the intake. The only way you can vent is if you are reading air AFTER the BOV. It is impossible to tune without an SAFC, that is what you use to make the actual adjustments. The A/F gauge is just to read and not control anything. Get most of your major mods first before you worry about tuning cause most of your major mods will change everything.
