worth turbo'n an automatic?
Autos run almost 18 second quarter miles. Turbo it and most run about low 15s/high 14's. It's a 3 second drop which is pretty significant. You won't be lightning fast but it will be definately faster.
Do you like your car? Why do you currently own an auto? What are your goals? Do you corner?
yea, turboing your car is great! even in an auto, it makes it 100 percent a totally different car.
besides, once your a/t blows up, swap it out for a manual.
in the meantime just install a shift kit and a tranny cooler and your golden.
http://www.2gnt.com/nuke/modules.ph...yfaq=yes&id_cat=5&categories=Automatic+Tranny
Category: Main -> Automatic Tranny
Question
· Final Drive Mod Install writeup?
· Where to get Fnal Drive parts?
· How much does the Final Drive cost?
· Is it worth it?
· How can i install a shift kit in my auto?
· Where can i get the A604 shift kit?
· How much does a shift kit cost?
· Is the shift kit worth it?
· Do i NEED a trans cooler?
· Do I need a tranny temp. gauge?
· Is there a good performance parts list for the A604?
· Will i be able to beat a 5 speed with all this stuff?
Answer
http://www.geocities.com/rbsounddesigns/finaldrivemod.html
OR
http://www20.brinkster.com/amljbs/finaldrive.htm
[ Back to Top ]
Bob Kise (Parts Manager)
Forums Motors Group
Phone: (810)714-3300
Fax: (810)714-5013
15123 North Road
Fenton, MI. 48430
[ Back to Top ]
Some only paid $90 and some up to $110
[ Back to Top ]
· Is it worth it?
Everyone who has done the mod agrees that the gains are quite orth the cost.
[ Back to Top ]
http://forums.2gnt.com/dcboard.php?...ic_id=32410&mesg_id=32410&listing_type=search
OR
http://www.rhinehart.net/transgo.htm
[ Back to Top ]
http://www.northernautoparts.com Or http://www.transtarindustries.com
[ Back to Top ]
About $20.
[ Back to Top ]
Once more, everyone that has installed one agrees, for the price it is quite worth it.
[ Back to Top ]
it can never hurt. Cooler is almost always better, and cooler trans fluid temperatures will prolong the life of your A604.
[ Back to Top ]
It helps. it's nice to know the fluid temperature, and to get used to its normal range of variation. This way, you will be able to see if something is going wrong - hotter than normal generally means you might wish to inspect the trans.
[ Back to Top ]
get all these parts and your set Transtar High Energy Rebuild Kit - K7200H $193.00 This kit uses the Raybestos High Energy clutches (kevlar)
Transtar Shift Kit - K72908J $26.00 www.naparts.com
Transtar Differential Pin Safety Clips - 72984 $5.00 each
2 needed and any trans shop (even the dealer) These are plates that sit on the outside of the diff and hold the pin in the assembly.
Transar Booster Valve Upgrade - 7208V $15.00 raises the line pressure for better shifts
Alumunim Accumulator pistons - part number unavailable (looking) $15
Phantom Grip LSD - 904 $271 www.phantomgrip.com
2600 Stall converter - $300 Hughes converters (core needed)
or 2800 Protorque High stall converter updated solenoid pack Shifter Solenoid - dealer part (depends on year 98+ use different plugs I think) or Precision International Part Number K31900-6
B&M Trans cooler - $45
Raybestos inline microfilter - $30
Autometer Trans Temp Gauge - $45
Drain plug - $5.00
Mopar Anti-Foam Additive Final Drive gear set Mopar part# 4773275
[ Back to Top ]
There's only one way to find out. Go do it!
all the info you need should be in that post and those links. the shift kit will make prolong the life of you tranny, as its more preventative maintenance replacing the seals and adding tensioner springs. you have the option of making your shifts a little sharper and quicker, unlike the *granny* style shifts the a604 currently does.
the cooler does just what its supposed to. keeps your trans. fluid cool, and cool = good. heat is your trannys worst nightmare.
I was on the phone with a guy from Hahn Racecraft the other day and he said they were running the auto tranny in their rs and it was running a 9.3 in the 1/4. Because of this i think it would be just fineto run the automatic.
thats a good point. i dunno if its stock or how ofter its rebuilt. but i do know when it was running 11,s with the 5 speed it was completley stock and they never had to reduild it. i know the car was dailydriven for qoite some time also.
that doesnt mean the same could be done with the auto but theres only one way to find out. and would u really plan on running 9's?
It is a lot harder then you would think to just swap a manual for an automatic, unless your an experienced mechanic or are willing to spend the cash for a shop to do it, its not such a great idea.
