94 6bolt swap first logs
codym
636
8
Dec 28, 2011
Amarillo, Texas
Hey fellas, I got my ECMlink cable in today and finally was able to make some logs. I am logging using TunerProRT, not the best of methods but it's what I have at the moment.
One thing I have noticed is I don't see a total fuel trim, just o2 trim. I recently installed 450s, and have the injector size set to 480cc on the MAF-T, due to my higher stock fuel pressure(48) than the turbo guys.
Running on 91 Octane
Anyways here is the logs I made today, in case the file name doesn't come out they are listed from..
-45-50mph cruise
Beginning of the log was a bit choppy, had a few hills in the area as well which didn't help.
Got everything smoothed out towards the end
-4th Gear 2k-5k
-60% Throttle from 2nd gear
-WOT from 2nd 2k
Made a few more pulls tonight.
0-40 cruise didn't look too bad, Think I just need to play around with the safc and MAFT to get my fuel trims closer to 100.
Had a drop in o2 volts..
Going into closed loop
While doing a 80% throttle pull, I noticed in the log during 2nd gear the RPM started climbing slower mid-gear.
I highlighted the area in the log, and found my o2 volts were 4.95! Any ideas what would cause that?
