Time Attack: El Capitan
Flash
3,359
14
Nov 30, 2003
Highlands Ranch, Colorado
At El Capitan, fastest time gets bragging rights and honors. Rules are:
Track: El Capitan
Car: Any Mitsubishi Evolution
Tires: Any tires
You must post you time, weight, power, tires, and vehicle information when submitting a time.
Anything else is a go, but NO driver's aids, two wheels on the track at all times. I just wanted to limit any chance of cheating as much as possible. I also wanted to keep the cars a constant, so it all comes down to driving skill instead of having the fastest car.
No nitrous!
Times
1.) 123abc
Time: 1.33.322
Vehicle: Mitsubishi Lancer Evolution VIII MR GSR
Power: 561hp
Weight: 1190kg
Tires: R5's
2.) Flash
Time: 1'33.458
Vehicle: Mitsubishi Lancer Evolution VIII RS
Weight: 1132kg
Power: 555hp
No driving aids, No TC, and No nitrous
3.) asian312
Time: 1'34.623
Weight: 1132Kg
Power: 557hp
Tires: R5
4.) Jeff91AWD
Time: 1'35.531
Weight: 1132kg
Power: 557hp
5.) 123abc
Time: 1'38.155
Vehicle: 95 Mitsubishi Lancer Evo III GSR
Power: 482 HP
Weight: 1071 kg
Tires: R5 tires
6.) jayseclipsefwdt
Time: 1'39.595
Weight: 1190 Kg
Power: 561hp
Tires: R5
7.) Pro3racer
Time: 1'40.2834
Vehicle: 2000 Mitsubishi Evolution VI GSR TME
Weight: 1156kg
Power: 499hp
Tires: R5
Default Driving Aids
8.) 4g63Attack
Time: 1'40:385
Vehicle: 2000 Mitsubishi Lancer Evolution RS TME
Wight: 1071kg
Power: 520hp
Tires: R5
Since no one else seems to want to post a time yet, I'll post a lap.
1.40.400
482 HP
1071 kg
R5 tires
123abc
I gotta transfer my PS2 saves onto my PS3 before I can give it a try. Might be a little while haha
This is a old record that I did sometime ago.
1:40:385
520 HP
1071KG
R5 tires
default driving aid
Just did this 5 minutes ago...
1.40.2834
499hp
1156kg
Tires R5
Default Driving Aid
Pick it up boys!
Time: 1.35.555
Weight: 1132Kg
Power: 557hp
Tires: R5
no driving aids, no TC, and no nitrous
Anyone know how to record from the PS2?
Time: 139.595
Weight: 1190 Kg
Power: 561hp
Tires: R5
I don't know how to record from the PS2. I just use my camera and uploaded it on youtube.
I think this one should include nitrous, that would be the only spot someone could cheat in. I think it adds a degree of difficulty, because if you use it improperly it will hurt the lap time.
Nah, you dont get to use nitrous in the real world on race tracks. It's interesting to see what people can do with just what's given to them. Personally I'd like to see just one car, one track, no mods. It removes all the variables and levels the playing field for those that dont know how to setup suspensions and transmission ratios.
PS: My nitrous runs generally netted somewhere around 3secs a lap and I used it all the time :shhh:
So are you saying you don't know how to properly setup a car? There are a lot of variables. It trains you to be a better tuner too, better driver, if you can drive a car and know what it needs then you improve as a whole.
In regards to using nitrous. There are plenty of good drivers here that will push the car as hard as they can, some outlandish lap time will definitely raise some concern.
Even though I said no driving aids, it appears Asain312 posted a quick lap without using any compared to the few that have. ;)
Not sure if this is directed at me, but I like to compare driver to driver. I'm kewl with tuning the cars, but it will cause big variations in laptimes. If there are concerns about my lap time I'm more than willing to post up my car's tuning specs, walk through of the track, and a video should proof be needed. But to be truthfully honest that 1.35.555 was a so so lap with still more room in it.
The wonderful thing about GT4 is its physics. Once you've track driven your car in RL, it's amazing how much tranfers into the game. And then there's the time left on the table where you're not worries about damage to your car, tires, personal safety.
Try and keep up :thumb:
1.38.155
482 HP
1071 kg
R5 tires
123abc
Slowly getting there.
Pick it up boys!
Time: 1.35.555
Weight: 1132Kg
Power: 557hp
Tires: R5
TV Capture card is what I use.
I think my graphics card has VIVO (video in video out) but I'd still need a S-cable to HD component adapter. My other option is to use the old Dazzle 80 and hook up the normal component cables or play it on my friends projector and record it. I'm thinking maybe the later since I'll be able to do commentary.
I found the most time in a lap through the first kink on the front straight (only need to lift off the throttle to get the nose down), the elevation change on the up and downhill section (hard to keep the fronts glued to the surface), the 180 'carousel' and the last two esses that lead to the front straight ( intensionally let the fronts push through the first corner like a FWD so I'm setup to get early on the gas for the left before the straight.
Yeah just a bit. It's probably more instinct than anything for me since its exactly the same corner as turn 12 at TWS ( just the opposite direction). To me the car feels just a little more settled for the large radius left.
I'm going to attempt to make a video with the help of a friend tonight. Anyone care to disclose their car setup?
So far I've been trying to nail the setup. Still at 1'36.4xx I know for a fact I can do better. My car doesn't like the R5 tires as of now for some reason, but I know there is time in using those tires, so I'm trying to make the full switch. ;)
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
