girlpower92
- 147
- 0
- Mar 24, 2005
perry,
Ohio
need to know if the fwd oil pan from a 6bolt is the same as on the awd 6bolt thanks
Nick 4g63 said:
ZiggysDSM said:fwd and awd oil pans are very different the downpipe goes through at a different area and there is not spot for the transfer case to fit on a fwd oil pan
so the answer is no they are not
I just got off of the phone with SBR, and there is no difference in oil pans whether it's a FWD or AWD.
The only difference is whether or not it's a 6-bolt or a 7-bolt pan.
<a href = http://www.vfaq.com/mods/early-late-engine.html>6-bolt/7-bolt Oil Pans</a>
WRONGIt's not mis-information. They both will bolt onto the block just fine. But use a fwd pan and good luck getting the tranfer case on.
WRONG
WRONG
Right now on my car, I am running a NON Turbo FWD 6 bolt oil pan on my Turbo AWD 6 bolt car. Please tell me how my transfer case and downpipe won't bolt on, because right now, they are both on without problem!
Yes, they ARE interchangeable.
