Stroker Main Cap Clearance's ?
Black94DSM
815
27
Jan 17, 2006
Madison Heights, Michigan
I'm looking for a pic of the main cap. I'm using the Eagle H-Beam rods with a 100mm crank.
Just trying to get an idea of how much material I will be taking off.
I know its on the board, I just cant find it anymore. I've done countless searches! I guess i'm just not using the right combination of words. ROFL
I actually think it was a pic from your motor that I seen. Do you have that pic still ?
Ah ok. Worth the shot.
Anybody else ?
Not much..
With manley I-Beams you dont even need to touch the main caps..
The manleys arent much thinner than the eagles on the big end.. So not much..
Wow! I honestly didnt even know that I was going to need to clearance the bottom of the bore. I just thought it was going to be a main cap mod. Interesting!
Thanks alot for the pics.
Yeah the Eagle rods do have a larger big end on them. So the caps will need to be grinded on.
No prob.. A machine shop actually did that (Although i was voting for the die grinder myself) So the clearance between the block and rods is incredibly tight so you might need to go a little further.. Just be careful not to cut into the oil galley!
Good luck with your 2.3.. They're a blast..
