boost leak pushing through coolant
Spades
273
4
Apr 29, 2007
Beaumont, California
just installed an Evo3 and performed a boost leak test and can hear what sounds like water droplets when i apply over 10 psi, there is no actual water dripping on the floor but there is definitely some activity in the coolant lines. I also hear an air leak, i thought it was the jpipe but i isolated the leak and found that its leaking from the internals of the turbo, are there seals inside that i can replace or does it need to be sent out for a rebuild? How do you take apart the turbo? i see a large C clip holding the compressor housing, is it as simple as just removing this clip?
To take the compressor cover off, yes, you remove the large snap-ring. Be very careful, it's a very powerful ring and if it slips off your snap-ring pliers can hurt. There is a rubber O-ring that helps seal the compressor housing and center section. It's very possible that this O-ring could be deteriorating, especially if the turbo is used.
delta448 - it was actually installed & primed last week and leak tested today, it ran great and i already logged a few pulls @ 16psi with it
MrBoxx - yes the turbo is used but the seller claimed only 10K miles on it, any other seals that i may as well replace while im there or is it just the Oring?
And anyone know what size Oring and what material it is? McMaster Carr has a wide selection of Orings offered in several different materials...Buna N', Viton, PTFE, silicone...? I want to order ahead of time and minimize down time since the car seems to run fine
It should be the same o ring. My old turbos o ring was completely shot when I tore it apart. It came out in hard pieces.
