FYI - MR downpipe and O2 housing
Calan
DSM Wiseman
7,250
398
Jan 16, 2007
OKC, Oklahoma
Just thought I would mention this, in case anyone else has come across this.
A while back, I bought the MR downpipe from SBR and bolted it up. It was advertised as a direct bolt-on for the stock turbo and O2 housing.
It fit... but barely. Aside from the pipe diameter/bolt problems (and rear flange angle since this was one of the early ones), the flex pipe was also tweaked slightly and snugged up against the oil pan.
Well now I'm putting my car back together, including a new EvoIII 16G, mani, and O2 housing. I test fit the downpipe, and it's a perfect fit. Apparently, this downpipe is actually made to bolt up to the Evo III O2 housing, which has a slightly different exhaust angle than the stocker. (RRE has a pic here)
So if you buy one of these for your stock turbo setup, do yourself a favor (in more ways than one) and upgrade your O2 housing to an Evo III at the same time ;)
I bolted mine up today and it fit just fine. The only thing with mine is the flex section is very close to the transfer case.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
