Head removal on a 2g.. With snapped tbelt
Tom3kGT
Mar 9, 2006
Mapleville, Rhode Island
Okay so heres the deal, my car snapped it's timing belt in october and I have been letting it sit until now. Today my friend and I decided we would take the head off and see if the bottom end is okay. Here is what we're working with.
So we drained all the fluids and my friend wants to take of the t25 and im telling him to leave the manifold on.. What should we do about the timing belt and everything that went wrong I just want to see if my bottom end is good and really have no idea how to do this correctly. We have a capable garage with a bit and air tools but still need some help.
Thanks,
Tom
Leave the exhaust manifold, turbo, intake manifold on. Remove all teh lines and the wiring harness of course. If you have a hoist this will be easy. If you don't take the hood off and you and your friend stand on the car over the bay and grab an end and pick the whole assembly up... If you dont have a friend (like me :( ), then take the turbo and exhaust manifold off together ans then the head and intake. It's still rather heavy. . .
since the the valves are most likely bent, just disconnect all the wires to the sensors and injectors, throttle cable, all vacuum lines, and upper ic pipe.
Unhook all the lines going to the thermostat housing.
Unbolt the intake manifold from the bracket under it, leave the intake manifold bolted to the head.
You can either unbolt the ex manifold from the head, or unbolt the turbo from the manifold. Personally, i would unbolt the man from head so you dont have to disconnect all the oil and coolant lines from the turbo.
Pop off the valve cover and unbolt the head studs. Once those are out, lift the head up and out.
That is pretty much it.
Head removal isn't that bad. Just unbolting stuff, and using a rubber mallet and a prybar (NOT on head mating surface) to separate the head from the headgasket and block.
What do you have questions on????
Also, when you are ready to replace the head (which will likely have damaged valves), here is the timing belt replacement mechanics guide:
http://www.vfaq.com/mods/timingbelt-2G.html
Please use the search option on this website, or check out www.vfaq.com or http://members.shaw.ca/costall/1000Q/ . These sites have ALOT of good information that any newer owner should learn.
