Aem Uego Vs Lc-1
SleepingTsi94
261
Apr 24, 2006
Corn, Iowa
Well I already have the lc-1 which has no gague. And I have a chance to sell for a lost of close to nothing. Whats the pros and cons of each. I like how the aem comes with the gauge lets here some input. Thanks
Try the PLX Devices AFR + DM5 combo.. comes with the wideband controller, sensor and a NICE VERY THIN GAUGE... also has an output for narrowand and wideband voltage output for logging or for dsmlink or chipped ecu that has a target A/F ratio!!! My buddy has the AEM UEGO, he wishes he got plx devices instead because plx one is cheaper...
or since you already have one that has no gauge.. just get a gauge for 0-5 volt wideband output!
mark
Lm-1 all the way, should be no discussion. Is ability to link up and record your readings, its rpm convertor that gives the most precise readings I have ever seen, the fact that it hooks up to a variety of other gauges.
I'm happy with my AEM, it has analog output for connecting it to other devices.... the guage does a great job, very accurate.
A logger or DSMLink aren't practical to monitor while driving in traffic, though. I've tried reading my DSMLink graph while driving, and I don't recommend it. :coy:
true that! it would be dangerous with your eyes off the road. but some may say saving cash is more important than safety.
If you have a logger I assume you don't have the link. The link you can configure for the lc-1 to monitor. Also, Logworks comes with the innovate LC-1 and has a speedo/gauge type interface where you can log your A/F ratios or just quickly look over at the lappy if you're that concerned......
Honestly, as long as she's not dyeing at idle and I have tuned it previously with no knock....i don't really care about the a/f ratio --but that's just me
The cheaper route, get the LC-1. Install it. Borrow or use a laptop to tune it. Forget about it.
Expensive/eye pleasing way but you get the same outcome: buy the $250 gauge
