mini zilo
- 783
- 18
- Jul 17, 2006
Chicago,
Illinois
I thought I'd share my mount I made for my palm pilot.
I used the closest thing to a peice of sheet metal I had. Whatever metal you use, make sure it is thin enough to fit between the center vents and dash. I'm not sure exactly what the peice I used is called, I know its for holding peices of wood together, but any sheet metal should work. I put it in a vise and bent it to a 90 degree angle.
Then I put a peice of velcro on it, and on the palm...
Next, slide the peice beneath the center vents.
Overall, it's a good sturdy mount, and I haven't had any problems with it falling off. It's an easy cheap way to hold the palm in you view when driving.
