Resolved Broken Wire Connector?
4g63-pwr
53
Jul 30, 2006
Houston, Texas
I was changing my alternator and I accidently broke a little black connector.
It is a black wire that comes out of the harness at the same spot as the alternator wires. It has a small black connector on the end of it with a little metal strap that screws in just on the other side of the oil filter. I'm not sure what it is and was just wondering before I randomly start replacing things. It appears to be a ground or something.
I was just wondering if I can splice a regular ground "eye-hole" ground connector to the wire and screw it back in. I can go take a pic if necessary. Thanks
Thanks man! It is the oil pressure light switch. I re-wired it so it should be fine now. Now I just need to get a new battery. I guess it got abused by the old alternator. It won't hold a charge at all.
Ok. I ran that wire directly to where it is supposed to go without that clip. Could that cause a problem?
My car runs fine but when I turn it off and the battery dies quickly. I'm going to get a new battery today anyway, but I was wondering if it could cause a drain or anything.
I noticed because when I got out of my car and lock it, the alarm starts going off like a minute later. I was going to just pull the fuse on the security so I could lock my car so the alarm doesn't keep going off, but there isn't even a fuse in that spot but it still works. It never had a drain or a problem like that before.
I was just wanted to know if that is causing a problem or if my battery just isn't holding a charge that bad. If my interior lights are on for like 5 minutes with the car off it will kill the battery that quickly
It sounds like your battery is just junk. If you have access to a multi-meter you should do a draw test when you replace your battery.
Will
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    Im looking for a set of injectors that are at least 800cc. Thanks!
    • DSM_Thorpe
  • For sale 2g 2g rear brace arms
    2g rear subframe brace arms. Missing one of the bushing spacers. No rust. Had someone looking...
