signal lights - there on but there not blinking
Talon00b
138
Jul 30, 2005
London,
I have this problem thats preventing me from saftying my car. When i signal the back lights signal fine bt the fronts just stay on? i tryed finding where the wires go but its so cramped i cant see... maybe im looking at the wrong lights what lights are saposto signal the front sides and front ones correct?
B :)
Do the back lights blink more rapidly than normal? Pull out the housings and wiggle the wires around and see if the blinkers come on. You probally have loose or corroded wires, if its not that then its the relay.
well the ones on the front flash next to the grill. but you said the ones on the back flash and the front ones dont...... that just a little wierd to me. if it was the flasher i would think that they all wouldnt flash but they would still light up when you activat them... yes i would check the relays but im not real sure were that one would be located but check under the hood on the left side "passenger side" and pull of that cover thing that hood pop up switch thing is and you'll be able to see the relays their a lil beter..........
hello all ok the back light ones flash a bit faster but then again i dont know what speed they went at before becuase it never worked when i got them. i just thought the lights were burnt out so i replaced them and no go. So where is this relay? and what one would i need? or is it not the relay sicne the front are working?
B :)
