MAFT question #2.
majik2k5
799
18
Jul 13, 2005
Lemoore, California
Another MAFT question.
Ok, so my MAFT is hooked up, and I'm gonna post some pictures so you can double check the work. Here are the problems though, my idle is high at like 2500 or so, and it actually seems like the car is somewhat slower than it was? It's also running rich at WOT, and I know it's possible to tune that out, but I'm not 100% positive. Also, if anyone else with a 1g running blow-thru could let me know what their mode settings are on the MAFT, it'd be greatly appreciated. Well, here are the pics. Enjoy.
ok, what's the easiest way for me to reset my ECU. I'm not at home, so I have limited tools here. Also, will that fix my 2500RPM plus idle?
Unhook battery for 30 seconds to reset the ECU.
Adjust the BISS (base idle set screw) located on the throttle body to set the idle.
