Pictures of my set-up (4G63T Elantra)
Status
Not open for further replies.
4g63telantra
454
Dec 10, 2004
Toronto,
Here are some pictures that I took today.
Thanks to everyone who replyed to my posts on this site so that everythign would work fine....
YEs but I think ill take them out and have it welded
That is the 1st intake manifolds Magnus ever made....
awesome. i couldn't tell what those blue things were, that's why i asked.
Wow, it's been a long time since I've seen one of them old Magnus'.
Nice ride!
Thats a right hand drive car. The brake booster is on the wrong side..
Wiseco 9.1 Forged Pistons
1990 6-Bolt Turbo Block
Clevite Rod Bearings
Clevite Main Bearings
B/Shafts Removed
Bore 0.020
HKS 272 Intake
HKS 272 Exhaust
AEM Cam Gears
Ferrea Dual Valvesprings
Ferrea Titanium Retainers / Shims
ARP Head Studs
Magnus Intake Manifold
Walbro 255lp Fuel Pump
AEM Fuel Pressure Regulator
RC 880 x4 Fuel Injectors
AEM Fuel Rail
B&M Fuel Pressure Gauge
1990 Tsi ECU EPROM
DSMLINK
Turbosmart Duel MBC
MSD DIS-2 Ignition System
Blaster SS Coils x4
NGK Plugs (BPR8ES)
T3/T4 60-1 Turbo
Turbonetics T3 Cast Maniflod
Tial 35mm
Turbosmart Supersonic
Full 3" Exhaust Piping
Ractive Muffler
Front Mount Intercooler
2.5" Intercooler Piping
2G 2" Aluminum Radiator
Flex-a-Lite 2x10" Thin Fan S-Type
Oil Jets
B&M Racing Oil Cooler
2G MAS
K&N Air Filter
show more pics of the car. Why is it right hand drive? What year elantra??
Its not right hand drive. You can see the steering wheel on the drivers side.
as opposed to...? regardless of rhd or lhd the wheel will still be on the driver's side. ;)
what year is that?
I guess im confused. I thought a left hand drive the steering wheel would be on the left and right hand drive would be on the right.
You said it's on the DRIVERS side. ROFL
I must be retarded then. I know I said its on the drivers side. Someone else said its right hand drive. How can it be right hand drive when the steering wheel is on the drivers side? Either way good job on the car.
That has to be a right hand drive car. Look where the slave cylender and brake booster is. Im a Hyundai tech. and every elentra is on the other side. I still want to see more pics.
Whether its RHD or LHD the steering wheel will always be on the DRIVERS side that's why its called the drivers side, its ok I didn't pick up on it at first either when you said it
The old skool magnus sheet metal is not the most boost leak friendly but guess what. Nothing beats being able to remove the intake manifold in a few minutes for room or watever other reason that doesn't involve the head. Nice project, i think i remember seeing your initial thread a lil while ago.
The car is left hand side, and the brake booster is on the right.
There is a long pole running under the dash from the brake pedal to the booster.
Thanks hope you guys like my project.
Ill be posting more pictures when I get more work done to it. :D
Status
