What Do You Think About This Setup?
TT_NS
203
Dec 2, 2003
What do you guys think about this setup. What do you think i should expect as in power 1/4 mile time and any other coments you may have? ill get pics as soon as i can.
*Engine Re-build Kit
Wiseco 9:1 comp pistons
Walbro-255 LPH (Fuel Pump)
Magnacore 8.5 Plug Wires
*Eagle Rods
*Greddy BOV
*High Pressure Cometic Head Gasket
Turbo Timer HKS- Type I
*ARP Head Bolts
*Cylinder Head(((*Highest possible flow from a stock size valve! Over 283.4 CFM on the intake side*
• Hot tanked
• Pressure checked
• Competition valve job *PLUS*
• Stage V port work
• New valve stem seals
• SS swirl polished, and undercut valves
• New guides
• Crower springs
• Titanium retainers
• Decked head surface
• New exhaust manifold studs)))
*Stage 2 Manifold Porting
* O2 Housing Porting
*HKS 272,272 Cams
*Prothane Motor Mounts
*GM MAF Translator
*GM MAF $155
Thermal 3” Cat-back Exhaust
*ACT 2600 Clutch Kit
*Fidanza Light Weight FlyWheel
Clinic 750cc injectors
*Front Mount Intercooler
*Greddy bov
Aeromotive FPR
Buschur 3” Downpipe
*Tel Intake Manifold
PTE 56 trim turbo
*Turbo Oil Line Kit
DSMLink
E-01 boost control
i do not have the exhuast system or any of the aftermarket fuel part on yet. And i am waiting for the DSMLINK and E-01 to come in the mail. So far i have noticed a large amount of boost lag. i get about 14PSI at 5k RPM's but that is expected especialy cuzz its not tuned yet.
So you just slapped on a shopping list of parts and want us to tell you how much it will make?
hmmmmmm....
Well I can tell you that your lag problem is probably due to three things:
-Base timing too advanced
-Huge exhaust leak
-Internal wastegate rod mis-adjusted.
other then that, whats the goal you have set for yourself? (HP, what you will do with the car)
dalatinromeo said:
He's right.
Don't forget to rewire our fuel pump, get a bigger fuel pump walbro 255 lhp, and afpr.
Prepare to get ripped for using "U" instead of the proper "YOU"
Stay boostin
LOL aight U was shorter. :thumb:
My personal goal was about 450 HP. Right now my Base timing is at 9deg. Has good responce at that deg. But the turbo lag is do to the turbo being so big. And the car vibrates like hell LOL. o i got the walbro 255 lhp and a FPR.
5k sounds crappy but anyways i would do a boost leak test, i always do after any job that has me pulling an i/c pipe, i pride myself in having 20+ psi at 3000 rpm with a 16g though.
Seriously man, flagrant misspellings can get you in trouble even a thread locked. It's a new effort to make the forums more comprehensible, just take the time to write it out next time.
Here are some older pics of my engine.
and if u ant got nuttin to add :shhh:
How about a non cruise throttle cable to clean up that engine bay? It looks clean. What front mount are you running?
just an off brand front mount that i got off ebay. its a bar plate intercooler
Perhaps a ColdAirIntake. I run a Holset with a 4" intake pipe that has my K&N where the stock sidemount once was. Cooler air is better and even though I have AWD I do not go 4-wheeling so hydrolock is NOT a concern. Mark
