To4b V Trim Compressor Surge
TurboChrged93
124
Jan 5, 2005
No where Fun, Pennsylvania
Mods in profile. I've tried adjusting my BOV to reduce compressor surge but it won't completely fix it. I've done searching thru about 100 threads on compressor surge and the V trim turbo's from bullseye and came to the conclusion that they are notorious for it. Also another note. I'm not getting major compressor surge when under anymore than 40% throttle above 5 PSI. If I free rev the motor or if I boost under 5 PSI partial or full throttle it flutters really bad and you can literally feel the are fluttering OUT from the turbo (where the intake would go) at the compressor wheel. Any ideas on reducing it? I can't afford to destroy this turbo anytime soon. Thanks guys.
I wish you the best of luck in conquering your compressor surge issues. Dave Hall, aka Bullseye, explicitly said in a thread around here somewhere that the V-trim "does not have a very forgiving map."
YEAH!!! WOOHOO! :notgood:
