Spool RPM poll. Well sort of poll?
curt2go
109
Aug 18, 2005
calgary,
I have been having a little trouble wraping my head around spool rpms and such so I want to ask a few questions to come to a conclusion.
(when I say full spool I mean if you mbc is set to 15 the rpms you are at when you hit that psi.)
1) 1g or 2g?
2) Size of your turbo?(eg. t25,14b,16g,20g etc)
3) Auto or manual?
4) Any mods to exhaust or intake side that would effect spool rpms(Downpipe,porting etc)?
5) Full spool rpms from a dead stop in first gear?
6) Full spool rpms from rolling around 2000-3000 in 2nd or 3rd gear?
If I have missed any thing then just add it. I have done a lot of searching and thinking about this but there is really no thread on this where everyone just puts their results for all to see. Thanx for the input and hopefully I will come to a definitive conclusion.. Please answer all the ?? if you are going to participate 3 of the 5 won't help me very much. Thanx again.. TTY ;)
:talon:
Very clever ;) , I couldn't help you anymore in the other thread because you have an AT. Hope you get your answer here.
You definately have helped me so far just want to get a consensus. i wish i could get this into the turbo thread instaed of the newbie one but it will have to do.. Thanx
PS You did not put your info in.. . :D
1. 2g gst spyder
2. ported evo16g
3. manual
4. exhaust side - sbr cast manny, tubular o2, stock downpipe and cat, 3" catback/n1 muffler,
intake side - K&N cone filter, stock intake tubing, 2.5" custom bent piping to fmic, 24x12x3 ebay fmic, more 2.5" piping, greddy type-s.
5. non applicable, dual stage mbc set to 10psi in 1st, reached that at around 2.5k. ####in fwd wheelspin.
6. 3rd gear pull. started off at 2.5k and reached full 20psi by 3400rpm. pulled hard to redline.
I'm too lazy to look back at the order....
92 Laser RS AWD
Set at 15lbs
Evo III manifold, entire exhaust is stock
Stock 14B
K&N filter
First gear I want to say around 4k, it goes so fast.
On a third gear slow roll, I say around 3200-3400.
1. 2g GSX
2. evo16g
3. manual
4. exhaust side - 3'' RNR o2 eliminator turbo back with high flow cat
intake side - Cone filter, 3'' intake, 2.5'' intercooler piping w/ 12x28x3 bar and plate FMIC, MAFT
9:1 compression, P&P head, 1mm OS undercut valves
5. never looked at a 1st gear pull, always watching the road
6. 3rd gear pull, hit 15psi by 2600 rpms. 5th gear pull, 15psi by 2600 rpms
Thanx alot so far guys this is exactly what i was looking for. There is more people out there with there car info. Come on guys I think the conclusions will be beneficial to everyone.. Well Maybe only me.. TTY :D
2g
56 trim- scm61
auto
smim, tubular exh. manifold, ext. wastegate, n1 downpipe, tubular o2 housing, 9:1 compression, think thats it
bout 4500
bout the same
with 100 shot....insant :thumb:
1. 98 GSX
2. Big 16G
3. Manual
4. 3" Full exhaust - Stock Manifold and O2 - No Porting - DejonTool SMIC
5. Injen Intake - Buschur Upper, Custom Lower (hard pipe)
6. 15psi at 2800 - 22psi at 3400 - 3rd gear
7. About the same in first, but with a 16G and GSX gearing, first is awfully short.
Cheers!
Andy
Good so far just ned more info. the more the better. I will be putting all the info into some form so everyone can have the broken down info.. So keep posting.. I hope I don;t get in troble for bumping this thread.. Thanx guys.. TTY
GILZTSIAWD said:
2g
56 trim- scm61
auto
bout 4500
bout the same
curt2go, isn't this what you werelooking for? :sneaky:
Yes but now i decided i was going to get more info and compile it into something everyone can use. Bad idea? :confused:
Not at all, I think it will be very helpful. I was just making sure you didn't miss it, I didn't see any reactions from you. :)
1g awd
s16g
manual
air filter, full 3inch turboback, turbonetics wastegate/external dump, no cat. small 5 inch johnny race car i/c. and a cracked leaking 2g exhuast manifold.
not sure about full spool in 1st gear
3rd 17psi by 4100.
1) 1g or 2g?
3) Auto or manual?
1) 2G
2)18G Chra clipped 10*
3)Auto
4)Stock exhaust, K&N super huge monster filter. :D
5)Full spool dead stop- 14psi at 4200ish give or take 200
6)Full spool rolling in second gear- 14 psi- downshift into first to around 4500rpm, nearly instant spool. Maybe a 2 second delay from the time the car actually hits first gear.
Hope that helps.
I look forward to see the compilation of all this stuff soon! :thumb:
curt2go said:
1) 1g or 2g?
3) Auto or manual?
6) Full spool rpms from rolling around 2000-3000 in 2nd or 3rd gear? :talon:
1) 1g FWD
2)EVO 3 B16g(unported)
3)Manual
4)2.5" punishment racing pressbent downpipe w/ test pipe and RNR 2.5" catback, GM MAFT in blowthrough(so no mas before turbo) just stock intake pipe, and KN air filter
5)Dont know, i dont hit full boost in first, FWD spinning
6) in 2nd and 3rd, i see 16 lbs of boost by 3000-3100(but with my awesome phantom knock :barf: , i see full boost at like 2400, but timing is like less than 5 degrees so i dont go anywhere)
1. 1g
2. ported 14b
3. manual
4. punishment downpipe, ported 2g manifold, ported 2g o2 housing catback
5. Dont punch it in 1st, NO TRACTION AT ALL ROFL
6. 2nd gear is great :) I hit 16psi by 2900rpms. It pushes me back in the seat. Cant wait to finish the rest of my mods.
3rd I get full boost by 3100rpms
1g dsm
apexi n-1 exhaust
ported evo 3 o2 housing
sbr manifold
garret t3/t4 v-trim turbo
I would say I reach 15psi around 3600-3800rpms in 2nd and 3rd gear. I don't know about 1st gear.
1) 2g
2) 60-1
3) manual
4) 3" exhaust, step removed on 2g manifold
5) dunno
6) 22psi 4500 rpms
1) 1g
2) T-04E 60 trim
3) Manual
4) Lack of air filter, ported 2g manifold (runners and dividers ported completely out), 2.5 in o2 housing that dumps to the atmosphere, 3inch back after that, Zero muffler at all.
5) Tire spin, starts at 3000 rpm
6) Tire spin again, however reaches full boost(29 psi) by 3800-4200 rpm's, reaches 15 psi at mid threes
  • Wanted 1g WTB 1g eagle talon A-pillar trim.
    Looking to buy driver side A-pillar trim, with pods preferred.
    • Walnuts
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
