mirkoelek
- 625
- 4
- Oct 4, 2004
phoenix,
Arizona
instalation pics, anyone
thank you
thank you
It is tight99gst_racer said:I have some pics of the tube I made to clear the PS pump. I do know what your talking about - it's a tight squeeze. I'll get pics by tomorrow.
that would be great, thanks. i do have external dump on my internal wastegate and now i was going to weld external wastegate together into one pipe and run to left side of my front bumper and make hole into the bumper. I know it sounds crazy but i think it would be interestingTAI92GSX said:Do you mean the Tial 38mm WG mounting on the #1 runner on the SBR exhaust manifold or 02 mountZ? I'm in the process of putting everything in and just put in the SBR manifold today, but mine is o2 mount routed back to the exhaust. I can get pictures of it if you want to see.
Nothing...just cost me $380 from Extremepsi for the VP o2 housing external routed back into exhaust.kicker91laser said:What are you gus using to weld the cast iron manifolds?
Wait a sec. Are you running an external wastegate on the manifold? Or and external gate on the O2 housing?mirkoelek said:that would be great, thanks. i do have external dump on my internal wastegate and now i was going to weld external wastegate together into one pipe and run to left side of my front bumper and make hole into the bumper. I know it sounds crazy but i think it would be interesting
SBR charges like $70 for the service. The tricky part is getting the metals to expand and contract during the welding and cooling off process. I believe they are "baked" before the welding and then slowly cooled down in an oven after. Not 100% sure though. Either way, SBR welded mine for me and it was one of the best welds I've ever seen. Here's Pics.kicker91laser said:What are you gus using to weld the cast iron manifolds?
no. its SBR cast manifold with welded flange for external wastegate.dsmpower1 said:let me guess do you have the ssautochrome mainfold. they put the wastegate flange at the wrong angle so it is impossible to run the tial wastegate with it, what you have to do is reangle the flange to like 20 degrees closer to the radiator to make it fit.
that is same mani like mine, and external w. is the same . can you give me some pics after you instaled all this. thanks in advance.99gst_racer said:Wait a sec. Are you running an external wastegate on the manifold? Or and external gate on the O2 housing?
OK, here's some pics. The first 2 are with the pipe taped together. We wanted to test fit it before we welded it together.mirkoelek said:that is same mani like mine, and external w. is the same . can you give me some pics after you instaled all this. thanks in advance.
As far as I know, 1G's have more engine beay space towards the front of the car. There wouldn't even be an issue with routing a dump tube.rjclagett said:If you have this same combo on a 1g, would I get to retain a.c. and powersteering?
