jtmcinder
DSM Wiseman
- 5,402
- 97
- Nov 4, 2003
Iowa City,
Iowa
I can only get this started. This is not my forte.
Zero toe in the front. Zero or very slightly toed-in (for stability) in the rear. The other reason to have some rear toe-in is that 2Gs toe out in compression, so starting with slight toe-in will get you to zero when weight shifts to the rear during hard acceleration. 1G AWDs have a similar issue, due to the dynamic toe engineered into the trailing links. If the trailing links are stock (unwelded), then you need some static toe-in so you end up with near zero toe under hard acceleration. If you have a 1G AWD with welded trailing links (which is suggested), then you can run near zero or zero static rear toe. 1G FWDs have a solid rear axle, so none of this is an issue.
Slight negative camber in the front and rear. 2Gs that have been lowered might want to eccentric bushings in the pivots for the upper arms to bring camber back to 0.5*; lowered 2Gs will definitely need to space out the brackets for the upper rear arms to get the camber back to 0.75* or less. This is less of an issue on 1Gs, since they gain less camber when lowered.
- Jtoby
special thanks to pneumo for helpful comments
- Jtoby
