jtmcinder
DSM Wiseman
- 5,402
- 97
- Nov 4, 2003
Iowa City,
Iowa
The #1 issue with regard to tire wear is toe, not camber. Non-zero toe causes the tire to scrub across the pavement all the time, stripping the tread off. Camber merely focuses the weight of the corner on a smaller amount of tire.
[Note: to most people, positive toe is toe-in and negative toe is toe-out. However, this is not universal. Therefore, I will discuss matters in terms of toe-in and toe-out.]
The combination of non-zero toe (especially toe-out) and high camber can kill a tire in 50 miles, but it's the toe that must be fixed to prevent this. I have run about 2.5* of front camber and more than 1.5* of rear camber without serious treadwear, because I was running zero toe front and rear.
With that said, I don't see much reason to run more than 1.5* of front camber on a car that is mostly for street driving. You get about this much on a 2G from a sensible amount of lowering (e.g., ProKit, not Sportlines), so no front camber kit is required. In the rear of a 2G, you should add shims (or washers) behind the brackets for the upper control arms to get the camber down to about two-thirds of what you have in the front.
Stock alignments include quite a bit rear toe-in, because this promotes stability, especially under heavy braking. If you have more camber than stock (due to lowering, for example), then back your toe off to being closer to zero. You still want it to be slightly toed-in for stability when braking, but don't run the full amount.
Keep the front toe at zero (which is spec) at all times.
- Jtoby
- Jtoby
