Steering Trouble
PieTSI
190
Aug 2, 2003
Jefferson Hills, Pennsylvania
Whenever I turn the wheel in my car lately it makes a loud creaking noise. Kind of sounds like a noise a ball joint would make, although I had the recall performed on my car about 6 months ago for the ball joints. It seems to be coming from the right side more than the left. It does not appear to be coming from the tierod ends. Whenever I took the wheel off the right side and turned the steering wheel the noise went away. However I put a jack with a light load under the rotor and turned the wheel, and the noise came right back. Its not coming from any of the ball joints but somewhere in the steering assembly that I can't reach right now without my buddies lift. It is 10 degrees out right now and that may be the cause for the noise but I highly doubt it. What I want to know is, does anyone know what the noise can be caused from, and more importantly is this car safe to drive?
I have the same embarassingly loud noise (especially in the parking garage where I work). I know I have a bad cv, it started clicking about a month ago. Getting raxles axle very soon. Soon after I got this noise. I pulled back the boot from the outer cv joint and packed it full of grease. NO clicking or grinding. 2 week later it came back though. Just another thing you may want to consider checking. I think the noise is the bad bearings scraping instead of rolling easily inside the cv housing.
Its not bad cv joints. I've seen bad cv joints many times. Not nearly the same sound at all.
Then I must have two problems. Because I know the CV is bad. I'll find out as soon as I get to replace it. If the inner tripod joint is bad, it will make that sound. Please don't be my rack, please don't be my rack. haha
It definitely was a bad axle in my case. I had both a bad cv joint and the balljoint. The balljoint was making this noise in my situation. Check out my cv I think I got to it just in time. The new raxles axle and balljoint is installed and the noise is now gone.
