anyone knows why this happens? Help PLEASE
mephist0
205
Apr 4, 2003
Salt lake city, Utah
Ok, first to start I purchased my car a few months ago and it has been running poorly, (the problem with the car is that it wants to die, which never does when it is hot and the tachometter dont work it goes up and down and when I step on the gas it goes to like 2000 RPMs and it goes all the way down to ZERO and it stays there till the rpms go down)By now I have been fixed some things on it I fixed the O-rings on the throtle body and checked for boost leaks and it leaks no more, I also replaced the Resistor pack and Coil pack, and the car is still doing the same damn thing, any experts on this stuff>????? thanks in advance
the one I got is the 1g so it's different cables and plugs, thanks :thumb:
come on guys there's have to be one that had the same problem before or some one that knows about this, Could it be a bad ECU ? :confused:
I already checked the capacitors and they didn't look bad at all, you think I should replace them?
Try swapping in a known good ECU first if you can get someone local to help you out with that. If you do that, you can find out whether or not the ECU is your problem before you go to the trouble of doing it.
okay, I'll do that. Any one else has any words/comments/suggestions?
OK this is an Update with my issues, remember I told you guys that I bought the car and it's was doing this crap since I bought it so I finally was thinking about the damn ECU and I went and took it out of the car and I found out that, the damn ECU it had was a different part # than CAPS and CAPS showed that this ECU # MD145902 or MD145903 Was for my car and the ECU that the car had in it was # MD128625 Do you guys think that this might be the problem>>???? OMG
http://www.vfaq.com/mods/ECUs.html
Yes, that's your problem. MD128625 is for a 91-94 not for a 90. One of the problems people encounters when they tried this is that the tech will not work properly.
now im gonna have to get rid of this ECU and it is an EPROM, sweet
yeah both the ecus are for 90's. So time to check the coil pack. I need to datalog cause, Im getting a slight missfire up in the higher rpm, so I need to see what the ecu is seeing and see if there is any coralation between the jumpy tach, and the missfire.
The thing is that I already installed an Ignition coil and power transistor and the only thing left is the ecu?
it does it all the time, and then when I run it hard and I stop on a red light it wants to die
it does some studdering and missfires. I don't have a datalogger
Have you considered a bad CAS sensor?
If the ECU is getting gibrish for a timing signal it will run like ass.
yeh I considered everything you could think of, I installed the cas, tps, ics motor, coil pack, power transistor and the noise filter.
Hmm...... Check all the sensors... MAF, coolant etc...
If it is'nt there check your fuel system.. Bad pump, injectors etc.
I also replaced those two sensors LOL the coolant temp sensor,and the mass
