Ludachris
Founder & Zookeeper
- 8,857
- 4,704
- Nov 12, 2001
Newcastle,
California
So, as some of you may know I just put a new motor in the car. It's a 2.3L with cams, 3" MAF-MAFT/blow through, 56 trim turbo, 850cc injectors, S-AFC, yadda yadda yadda. Obviously, this being a completely new setup, I was expecting some issues to begin with anyway - no biggie. I can't keep it from stalling.
It starts up fine and idles at 900 or so when warm. However, when I free rev it and let off it dies. If it's been running a while, I can't get it to start up again to hold idle. I have to let it cool for a while then start it up again and the same thing happens. I checked the resistance on the ISC coils and they're fine. And the fact that the idle speed adjusted as the car warmed up tells me that the motor itself isn't bad. I've checked all the vaccuum lines. I'm wondering if it has to do with the breather on the valve cover...
Also, while I had it idling, I saw that the O2 trim at 1k were pretty lean so I adjusted the IDLE knob up 2 clicks to get the O2 trim near 100%. However, revving it to 2k shows the O2 trims drop down to about 50%. I'm thinking I'll have to richen up the idle and lean out the base? Oh well, I just want to get it to not stall first.
I know 850cc injectors are pretty big and the cams will add to the problem, but I wanted to know if this was a common issue with 3" blow-through systems (with big injectors and cams) or not. These are my cam specs:
Lift: .391 - .379
Duration: .258 - .255
@ .050
Separation: 106
Any help would be appreciated.
Lift: .391 - .379
@ .050
Separation: 106
