bm tranny LSD insert will people tell me what you think?
I've had mine for about 8 months now and I can't really notice much of a difference. My torque steer is gone, and no wheel hop, but my wheel hop days ended with motor mounts. Now all it does is spin 1st, 2nd, some of 3rd. I got it dropped about 3 weeks ago with some agx/pro kit combo and my traction actually has improved. My shocks were worn slam out, so didn't help much. If it's a warm day out, the car clings to the road now, but not sure which actually helped which since I did mounts/bmt lsd/2100/act flywheel all the same time. Hope this helps. 2g fwd evo16g/usual mods minus safc/injectors.
BTW- sweet ride, not many 2g's out there with the smiley face front anymore.
Well i got the phantom grip which is the same thing. And yes their is a difference in torque steer and in drag racing. I went from a 2.1 in 60ft time to a 1.9 so thats good for me. and now i light up both tires every were i go. good product i thinks its worth it
I've had mine for almost two years, no complaints. I haven't dynoed my car since the 60 trim but I am sure I have at least 300 hp. It has held up good for me. I installed it when I was on the t-25 noticed a huge difference then, barely lost traction. Now its a different story, spin through first and second, but it is still holding up. I would reccomend it, if your on a tight buget its the only way to go. Install was easy too, (did it when I put my clutch and flywheel in) as long as your comfortable taking your trans apart. However I have heard some not so good thing about the phantom grip. :confused: The B&M unit gets :thumb: :thumb: from me.
