jfdid
- 267
- 1
- Dec 18, 2003
Calgary,
Hey guys, I'm still struggling with this setup.
680's, 190 lph pump, 3" maf, and Maft 2.xx. 16G Other mods in my list if needed.
Basically my battle goes like this. I'm running 17PSI or so, and I've gotten things nailed down pretty well I think. I'm knocking in the 1000Hz+ range(WOT knob) at anything over 5000 RPM, 2nd gear and up. So, I richen the WOT knob up one click, and then the car rich bogs, with little to no knock. I lean it out one click, and I'm knocking again.
So, I'm not sure where to go from here. My timing is at 5 degrees, so I don't feel that should be a problem at all.
The only other 2 things I can think of is a) a boost/vaccum leak or b) FUEL
a) I've tested a couple of times and found nothing for leaks, seems ok to me, so lets move on.
b) I've a couple of theories...
-unmatched injectors. They're brand new, but maybe I should get them flow tested?
-not enough fuel pressure. I have the 190, rewired, so I wouldn't think that this is a problem? I've heard stories that the #1 cylinder recieves the least amount of fuel, maybe it's receiving less fuel, and knocking. Is an AFPR and gauge in the works or what?
-not enough fuel pressure. I read somewhere that the stock lines aren't sufficient to support even 190lph, and to run SS lines all the way.
Any ideas, anyone? Would the DSMlink help me out here or what? Does it have finer adjustments than my MAFT? Thanks guys.
...sounds like bad news to me, I thought it was a bad MAF or just the box, I was going to try another one from a friend but seems that it wont be solved. I have the exact same problem as you Devilsperm, and racegas didn't solved it, just avoided it, let me explain... since I have a Keydiver eprom for my 750's I have to set for 450cc inyectors. Idles is at +15, mid 0 and wot 0...at that setting, with pump gas, it is ideal for about 17 psi, with little knock...If I try to raise the psi, it would knock, so I set wot at +5 and there starts the bogging thing. With race gas, since you have to tune leaner, I had to put it in -15%...Problem "solved" . Now I have a couple of more psi, and a bit more timing with race gas and my wot knob is at 0 but with 25psi and race gas, I did 12.2 like that, but I really cant add more fuel if i want to raise boost because It would bog even on race gas at +5%...and that is pissing me...I was thinking...and "probably" the problem is at the hz that a stock or 2g MAS should overrun...when the stock maf overruns, you are just tunning by rpm (when using 1g or 2g mas +safc). And since the MAFT is meant to emulate a 1g or 2g mas...probably there's something up there...at high hz...I'm just assuming but if somebody have a better idea, It would be good to hear it
Hope you guys find the problem
