AEM users please help
93formula
35
Jun 18, 2004
Thornton, Colorado
Alright, I have a 91 tsi with a b16g, 550 injectors, GM Intake temp sensor, GM 3 bar map, and obviously a AEM. Now I have every sensor setup and I'm having a problem getting the car to start. It will turn over for about 2-3 seconds then back fire. The car seems to be getting fuel and spark. I have ignition set at 7.96. I've tried tuning the crank injector time table (set at 90 right now) and the warmup enrichment (going from 60 to 0). What am I doing wrong that it wont start?
The 1300, but I got the car started. I think I'm a bit over my head with this thing.
Not what box are you using, what version of the software? If you are not on v1.13 then go to the AEM forums and download it.
Also, go through the wizard and make sure your coils are set on mitsu and not mazda.
jeff
I have v 1.11 and the 16 g and 550s are going away once the motor is broke in. I'm going to be using a gt30r and really big injectors. Maybe nitrous.
So what did you have to do to get the car running? You might be able to help somebody else out. ;)
