Wont boost over 11lbs and Dont have my fuse box covers...
cfinch1
Jun 15, 2004
Las Vegas, New Jersey
Ok so I bought a joep manual boost controller got the car to boost up to 11lbs and I keep turning it but no matter how far I turn it 11lbs is what I get. Now I bought my car from an auction and it didnt have either fuse box cover under the dash or under the hood. Is there a site with a diagram from what fuse goes to what ? The main one I need is the fuel pump so I can install this walbro I got but I would really like to be able to tell what all of them are.
Its a 94 eagle talon non turbo with a 6bolt swap and my joep mbc is all the way down and still wont go over 11psi :(
how is your boost controller installed?
here is a small diagram I made hope this helps, mine was installed wrong and it only boosted 10.5 psi so maybe thats your problem and for your fuses goto a junk yard and get a cover from them, I also had the same problem
Jon
First it went from the wga to the bov line but then i switched it over to the j pipe and same thing about 10.5 pounds .....
