Older (clear blue) Greddy TT manual and reference docs
Guys, since I was searching online here today for info on integrating a Greddy TT with an alarm I noticed a bit of misinfo sometimes and no true reference materials for the older Greddy TT. (The ones that came in mostly clear blue I guess type I?)
Since I did get a copy of the install diagram page and the owners manual, and it is no longer available on Greddys website I thought I would post it here for future owners reference.
With cars changing hands, Ebay sales etc I thought this would be something someone including myself will one day need, and I wanted to post it to clear up a couple of discrepancies regarding wiring.
1) 2gs have two IGN wires use them (not an Acc) so your fans run, and connect the alarms ign sensing wire to acc instead to avoid problems. (remote starts see a professional installer)
2) Brown wire is for the Handbrake. However the safety features may have to be enabled, or diabled depending on your use of this wire and disconnecting the battery etc will not reenable them. If you don't know the procedure you may not be able to get the safety features to work.
That being said here are the materials
First I'll post a color document that explains what color wire does what, and what voltage etc should be on the wires you tap. I think some Greddy harnesses were backwards as there were many complaints of the timers turning off when the Greddy harness was used.
Testing the wires for their actual function before wiring the TT into them will always ensure you don't have this problem.
I'll try to post the Manual in a second post as it doesn't want to let me in one post. It will have to be page at a time as otherwise it is too large.
Owners manual Index
cover page
pg 2 installation w/ diagram using harness
pg 3 installation w/ diagram not using harness
pg 4 wiring diagram for ignition 1&2/ 12v+ and Ground
pg 5 harness connections handbrake and speedo
pg 6 button functions
pg 7 parking brake function check
pg 8 above cont. and eliminating pb feature
pg 9 speedo sensor check
pg 10 basic operations
pg 11 auto timer and setting
pg 12 setting engine rpm
pg 13 voltmeter mode
pg 14 manual mode and prog manual mode
pg 15 music mode
pg 16 music note chart
pg 17 programming the music notes
pg 18 above cont.
pg 19 correcting, entering, & deleting music
pg 20 above cont.
pg 21 changing opening music (no music option also)
pg 22 changing closing music (no music option also)
pg 23 LED controls
pg 24 above continued.
Finally Thanks to DSMTuners for hosting this info, and to my son for "helping".
Hope all of you Greddy TT owners out there find this info useful.
I skipped the page that showed what was included (pg 1) as if you have a brand new one you probably have the manual too!
pg 10 11 12
pg 13 14 15
pg 16 17 18
pg 19 20 21
