timing belt cover
mustg5
278
Nov 3, 2003
i have the lower timing belt cover on, how important you think it is to have the whole timing assembly covered. Can it go without?
you can but I wouldnt recommend it. Dirt and dust will get into areas and cause wear on the timing belt. I would keep it on. engineers put stuff on for a reason... sometimes :)
haha yea....thanks for the input, only reason i ask is cuz the motor is in the car and it is a pain to put it on with it in the car, should have done it before i put the motor in, my stupid ass wasnt thinkin. Thanks
If you have to lower one on then the upper one goes one with like 3 bolts. If takes like 45 sec.
On a 2g there different than a 1g.......the 2g have three peices....lower, middle and upper. While the 1g is only a 2 peice
If you toss a pebble about the size of a BB up into the belt, your chances of skipping a tooth are fairly high.
Do ya feel lucky? Well, do ya, punk?
Get the cover back on.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
