Kookykrispy
- 76
- 1
- Jul 6, 2004
Albuquerque,
New Mexico
There are lots of threads on here cautioning against cutting the springs as a method of quick and cheap lowering of your car. I agree that simply cutting the springs and running stock shocks is a definite no-no
If I was rich, I would have just purchased lowering springs, but I didn't want to spend more than $550 total on my suspension and I figured the money was better spent on quality shocks.
In short, I removed 1.5 coils from the tops of each spring and used the money I saved on springs to buy the best shocks I could: Koni Yellows.
I had researched some information and found that stock '97 GSX springs are 277 #/in front, 165 #/in rear
eibach springs are 320 #/in front, 170-217 #/in rear
(stiffer by 15% front and 15% avg (3-27%) rear)
From what I could gather, it seemed that the spyder application was closer to that of the GSX due to the increase in weight from the convertible.. So I figured (and hoped) that if I removed aproximately 15% or so of the spring height that would be close to the spring rate of the eibachs and give me the slight drop I wanted.. (1-1.5") There was a bit of guesswork involved.. and I understand that the 2g uses progressive rate springs, so thats why I started at the top where they are wider. After careful measuring, I concluded that 1.5 coils from the top was about 15%..
I am quite happy with the end result. I have been driving the car one day now, I have the konis set on 1/4 turn in from least stiff... and it corners like its on rails. Body roll is severely reduced in low and high speed cornering. I have not felt any contact on the bumpstops (which I left un-cut) and the car absorbs bumps nicely. I drove on some pretty rough roads, with potholes and speedbumps... and on the freeways at high speeds. no problems with any of that.
The car sits about 1 1/4" lower than it did before.
Here are some before and after pics:
I'm convinced the key to doing this successfully and achieving results that both look good and perform well is careful measurement and being very careful to not cut too much of the stock springs... it will only work for a mild drop since we are working with factory springs here... and you MUST spend some coin on quality shocks. Just cutting the stock springs and using stock shocks or OEM style shocks will probably yield unsatisfactory results. I used a heavy duty grinder with a metal cutoff wheel to do the slicing. I paused halfway through to let the spring cool in an attempt to not overheat the metal, which will ruin the temper. I then filed the cut end and painted it black to protect it (hopefully).
I'm going to autocross this car on Sunday. I'll post more about my findings and results after I race on Sunday.
If I was rich, I would have just purchased lowering springs, but I didn't want to spend more than $550 total on my suspension and I figured the money was better spent on quality shocks.In short, I removed 1.5 coils from the tops of each spring and used the money I saved on springs to buy the best shocks I could: Koni Yellows.
The car feels great driving around town and its really fun to throw it into tight corners at speed. It hugs the road and now literally feels like a new car! The ride is a little stiffer than stock, but still comfortable and smooth which is exactly what I wanted. On bumps or rough roads, it feels fine and is not harsh, bouncy or otherwise uncomfortable. I cannot say enough good things about my konis!
