4130
- Jul 1, 2008
Denver,
Colorado
Ok let me start by saying that I cannot datalog anything from my car. I got a brand new datalogger but It will not log. My question is do I have a burnt up ecu or a bad connection? I also have a very crappy idle it idles like if it has cams. Now my car use to idle alot better but it all started after I swaped out my upper intercooler piping for a hard 2.5 pipe, and a non turbo throttle body. I though my idle was caused by a boost leaks but even after I fix them it still didnt seem to idle a hole lot better. Now this is the reason why I think I could have a bad ecu. When I was installing my upper intercooler pipe I forgot to disconnect my battery so I accidentaly grounded my positive side of my battery with my intercooler pipe that was touching my transmission. It spark for a good second
could that cause my ecu to go bye bye? I also tried pulling a check engine code with a code scanner but it could not connect to my ecu?
So should I try to put in another ecu or is there a way to check if I have a shorted wire or a loose connetion at my diagnosctic port goint to my ecu?? Oh bye the way my car is a 92 mitsubishi eclipse gs-t. I would appreciate any ideas, answers or questions Thank you!!!
