Slow old poop
- 707
- 7
- Jul 24, 2005
Cedar Rapids,
Iowa
There I was, going down the front straight at Midamerica Motorplex (south of Council Bluffs, Iowa) when it happened again. I had just passed two Vipers and was watching the modded M3 coming up fast in my mirrors and -- kablooie -- all three cars disappeared in a huge cloud of blue smoke as my oil filter blew a seal -- again. Boy, does that make a mess!
I am running 120 psi oil pressure at 7000 rpm and 20 psi boost. The first time it happened, we blew an Amsoil filter (it came with the car, so I used it). We replaced the Amsoil with a Wix filter and ran a couple more events with no problems. Now I dunno what to do.
I know drag racers don't have this problem (some of the ones I ask just scratch their heads and say, what filter? Who uses a filter?). Or, if they do use a filter, their run is over in 10 seconds or so, and they never have a problem. Constant WOT at 120 psi seems to do in the filter seals.
I didn't blow the filter at the last two events, probably because we were suffering boost leaks, and I could not hold a constant 20 psi. Now that we have all the leaks fixed, and I can run a solid 20 psi, it blows the oil filter. I assume there is a relationship there, n'est ce pas? Or not? We want to turn the boost up to 29 psi on race gas, but not if we are going to blow the filter.
My wrench, Mike the Mechanic, is finding instructions for modding the oil pump to lower the pressure down to 80 psi or so, but I thought I'd ask the list here if (a) does anybody else have the problem? (b) what did you do about it?
Thanks for your help
Rich
Rich
). After Rich blew the first oil filter this spring I searched on here and found out about the oil relief porting. I was going to do that the next time I had Rich's car for some work, but we haven't got around to it yet.
